View the thread, titled "5 Bedroom House, 18 Rads, 1xBath, 3xShowers - Combi or System Boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Why not replace gledhill with equally brilliant economy 7 instant water coil ? Why on earth would the op base any financial calculations on a British hash price? Could probably fit two pressurised cylinders and a boost pump, air heat pump new boiler and garden gate for same price!
Warning to OP when getting other quotes hide the BG paperwork and don't tell others you have had a BG quote as they will simply add on 5% because they know they will still be 30% cheaper!
I recently took out a Gledhill systemmate hot water tank, massive rectangular box 250 ltrs of junk.
I installed a Worcester 42 cdi in its place and the flow rate to the showers has increased!
The Bg guy is correct regarding the softened water, Worcester will not allow softened water in their boiler, can a hard water supply be connected up to the boiler for the central heating side? It is ok for the domestic hot water side.
Thanks for the reply. Thats good to know you are getting good results with the Worcester.
I telephoned Worcester and they confirmed that CH side must be hard water (due to aluminium heat exchanger I think) but DHW side can be softened as heat exchanger is stainless steel. I can isolate the water softener so that the CH could be filled with hard water. But would the boiler still need a hard water supply ?
If you don't wont pellets then use wood chipping boiler or even log
Don't forget air and ground pumps! Was in Slovenia they have some crazy log furnaces in domestic with massive thermal stores (thousands of litres)!
If you have a cesspit, stop using bleach and get an anaerobic digester, but with mains gas you probably got running water and all mod cons?
Getting another quote from local guy. Thanks for the replies.
personally I think a thermal store with boiler back up and solar panels would be a sensible option if you have mains gas. From what I have seen with pellet burners, most of the pellets are imported, and will soon rocket in price as demand increases and its hardly carbon friendly carting them half way round the world to the uk.
I'm not a big fan of solar on thermal stores
Simply because the householder generally just leave boiler heating store all time and solars don't get chance to work efficiently
And the pellets are made about 30 milled from where I live (ballcas)
I've fitted a couple of grant spirotec wood pellet boilers and must say very impressed with what I have seen so far
No hard water through combi or any plate type heat exchanger causes scale. Phosphate type softness isn't best. That's why if over 200ppm you recommended to install cal mag or similar on combi!
Hi.
Do you want to tell us where you are - if any of the experts here might be able to give you a quote.
Back to OP - I'm a fan of combis! In my house we have a combi and 2 showers - I've never tried to use them both at the same time so I don't know what would happen.
but when I'm in the shower the kids frequently decide to come clean their teeth and flush the loo and wash hands - there is small minimal impact on the shower. But I'm sure you know incoming water pressure is important as well as the size of your boiler.
Finally, please be clear I'm not a heating engineer and the other guys on here write a lot of sense. If we had more space we probably wouldn't have a combi because my hubby also thinks along the same lines as the other heating engineers.
then the installer hasnt set it up correctly and explained how to use it properly, whats cheaper and better sun light or pellets made from chopping down a tree, grinding it into a mash, forming pellets and then moving the end result to the customer and burning it and producing co2. sometime the world will see snese and go for the option that relies on sunlight with a backup mechanism and not vice versa!!
The heating side would yes, but get the filler loop tapped off before the softener and the job's a good'un!
The principal of a thermal store cylinder is similar to that of a buffer tank or accumulator. Essentially it is an efficient method of linking multiple energy inputs together, and provide domestic hot water as main pressure. Anyway I don't think it's fair to the o.p to carry this on. On his post if you wanna talk bout it mate then pm me....
croppie if you wanna remove are post up to are suggestion I think it's only fair that the o.p don't have us trying to get one over on the other
I'll leave it running Ryan, It's an interesting exchange of opposing views and doesn't come across as one upmanship. As long as it's kept friendly then I'm cool.
No set up correctly at start explained correctly
But some customers always think they now best lol
Why not get a combi three zones one for a cylinder coil on vented cylinder fed by tank to a pump just for showers and have instant hot water for all other outlets?
Just a suggestion to put the cat among the pedgons..
A system boiler would enable you to make better use of the showers and baths you have. A combi would defeat the object of having numerous showers and baths if they cant be used.
There are many ways to skin a cat depending on the cat. TBH if its a decent size house, it should have secondary return anyway.
Agree most do just depends on location of cylinder to bathrooms
Combi on that lot is always going to be insufficient. Any manufacturer would also agree. Stored DHW is the only way to go. Don't be scared by BGs price, they will be much more than a decent local installer.
I will not read the comments below - but really a combi will not do they are rubbish and
go wrong esp in this set up.
All the sensible tradesman below will tell you to fork out for a decent system set up
you could even be lookin at a dual boiler system in my opinion
CHK
Mike is correct get a BG quote and we normally half it and still make a good wedge
I agree, go for an unvented and system boiler. get alternative quotes from a xouple of local guys and the price will be a lot less than the Bg price.
CHK
What a fracking stupid waste of internet space.
If you cant be bothered to read the previous discussions, why bother to comment?
CHK
Combi rubbish not in right application? Agree wrong for this set up, ACV cylinder and high output system boiler with water softener on DHW & DCW excluding potable water. Get cylinder with solar flanges for future?
Also possibly zone floors ?
Reply to the thread, titled "5 Bedroom House, 18 Rads, 1xBath, 3xShowers - Combi or System Boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
