secret squirrel
I need some advice from someone wiser,
Today, I looked at a job:
on the face of it, it is to plumb in a radiator which is already fixed to it, about 3 feet above the bath, (modern arty rad), not happy about the pipework as it would have to go under the bath!
Re-site the shower pump and put in a new shower tray and thermo shower.
There is a problem with the pump at the moment, it cuts gets cold when someone turns on a hot tap. I looked at the hwc which is behind a wall panel which had to be removed to gain access, it is in the kitchen and you have to stand on the work surface to see anything.
The immersion wire is about 1.5 metres long and is extremely brittle, it is on a fused spur! (I know this is wrong and needs to be sorted, I think the cable can be a max of 450mm) Anyway, there was only 1 hot water feed from the tank, there is hardly any room to move in the space(this is, I think causing the problem with the power shower).
The shower tray is huge, about 1.5 m by 1.m and is not square it has an oval shape to it. Plumbing the waste is a nightmare, it'll have to go through the bath waste or try and connect to the existing shower waste, the new shower is moving to a different area of the bathroom. The waste can't go straight through the wall because it'll have to contend with a flat roof! (hard to explain but its not going to be easy)
I didn't go to the loft but I am told that the loft tank only feeds the shower and the hot water cylinder.
After the shock of the hwc alarm bells were ringing. The homeowner said he'd do all the work himself if he had the time but is waiting to hear about a new job, may need to sell the house so needs it all done quickly. I was told that other people who have looked at the jobs in the house have wanted to charge ridiculous money.
Here is my dilema! I want to walk away from this one, its just a complete nightmare from start to finish, other more skilled and sensible plumbers have also walked, I'm worried what else I'd find. SO, as a learning curve for me: I think its a 5 day job, worth about £1k, 5 days to cover the nightmares and the £1k should cover contingencies.
Do you agree with this assessment? What other potential issues could I expect to come across? anything that I've not considered?
Please feel free to be critical🙂
