A real brain teaser, its got me beat
View the thread, titled "A real brain teaser, its got me beat" which is posted in UK Plumbers Forums on UK Plumbers Forums.
So Derrick you can see all of the pipework from the meter to the services? There isnt anywhere that you cant see? Im just baffled how this is happening...there has to be a leak somewhere...and theres a lot of people on here who want to know where it is haha
Not quite from the meter, but from the main SC (no 1) in the house, and then from SC 2 which goes to the bathroom, just feeding the cold side of both the HB and bath, then the WC
here is an update 🙂
I got there and still cant put the kitchen sink in, this chippy hasnt cut the hole for the sink yet (his router died)
I went up in the bathroom expecting the worse, the pressure gauge had dropped .2 of a bar, not much at all, I thought, the meter was still turning though, but still slowly
So it hasnt got any better or any worse, but I cant understand why the meter is still turning and I have lost so little pressure
Bit of an anti climax, isnt it ?
Still no closer to solving this 🙁
Anti climax ain,t the word , i feel more deflated than watching 44" chest lol , at least you know for sure that you do not have a leak ! now you need to look at the incoming main or get the board out and show them it must be a dicky meter
I had the guy out before, he said the meter was fine (how he knows without having it dug up I dont know) he said it only moves when water flows, well it was still moving and I still had pressure (for over 24 hours, standing pressure) so something is wrong somewhere
Im sure i read somewhere that if some drunk youths walked by in the night and decided it would be funny to smash up the meter face (assuming its external) that the water board would replace the meter. wink wink.......
That would only happen if the plumber left the cover up and they used something from all the rubble outside, though
I suppose I had better start leaving the cover down in case that happens 😕😕😕
Don't think they have to be drunk.
I came across this thread a couple of days ago and wondered how long it would be before someone suggested changing the meter. I'm dontknowitall on purpose but I think you've done enough to try an eliminate all the other possibilities.
One other thought I had was to cut the house pipework as near the meter as you can and pop a stop end on the incoming mains (then check the meter then re-solder). I'm intrigued now as to what the answer is - hope you tell us after nine pages of this!!
As much as I would like to, the poly is underground, from the meter until it comes up in the kitchen, then there is about 6 inches to the first SC
And you said with valve no.1 (main sc) closed the meter stops.......... which kinda negates stopends on the mdpe..... can't be the mixer hot tap letting back into the cold supply cos you're running a combi and what you would have there is a loop, which once it was up to pressure the meter would stop running........ no leaks, no major pressure drop........
hmmmmmmmmmmm............
Old Balvenie time methinks.......... and another day pondering someone elses problem rather than my own!
Oh. And thanks for all your messages about me handsome visage.
I love you all too.............
I Think............
Ooh! Ooh! Ooh! Thought of another one!
What leg is the heating filler loop sitting on? What pressure is the heating system at? Is the fill valve letting by and throwing water out the PRV?
sorry, that is fed from SC 2, the only bit that is a suspect leak is from SC 3
You know what it is now don't you Derrick! you're on the windup now lol
Fair one, I'd do the same!
I wish I was,
The gauge has shown very little drop in pressure, the meter is still turning (AND I still cant get the sink finished)
The cold feed to the bath has a gauge fitted, the hand basin cold tap is off, the WC is on, and the cistern is full
could you put a dye in the cistern to see if its is passing? there wouldnt be any chance that the water is just drying up? no de-humidifiers or anything?😕
sounds like a nightmare
have you isolated the cold feed to the boiler with all the stopcocks open and then checked the meter for movement? with a water meter fitted the expantion in the dhw pipe could pin hole the plate hex, with out a mini expansion vessel fitted inthe cold feed pipe to take up the expation of the dhw it could leak mains water into the heating circuit exiting out of the prv or down the condensate,just isolate cold feed to check?? long shot i know but hey, were all trying with an headline like "a real brain teaser,its got me beat"
Hey derrick hows about you disconnect everything on the sc3 leg and cap off , then check the flammin meter and if it still moves get a shotgun out. lol
I have to say thats the first thing i would have done, cut the pipe and cap it off. All this umming and arring about what it might be is ridiculous, just disconnect it and start again.
Reply to the thread, titled "A real brain teaser, its got me beat" which is posted in UK Plumbers Forums on Plumbers Forums.
Derrick229,
Dan,
