baer in mind im doing exams tomorrow and going by my answer you guys might think im in trouble but here goes!
2.75 x 3.25 x 2.4 = 21.45m3 appliances permissable in space
based on there being openable window or door to outside
cooker room larger than 10m3 no ventilation required if door or window to outside
sink heater room larger than 20m3 no ventilation required window required
space heater requires 100cm2 min + 55cm2 for over 2.7kw output
so venilation required for the above would be 265cm2 for the above
am i miles out or kind of there lol
Your right about the cooker and the Flueless sink water heater, But......
For the Flueless space heater in a room???
I see how you've come to your answer, but you've skipped a step. I would look at that table again and pay perticular attention to the heading "Maximum appliance rated input limit (net)"
so??
21.54m3 room x 45w per m3 of room volume = 969.30 w
max inupt permissable for this appliance is 969.30 watts so 0.97 kw
meaning the space heater is to large to be allowed to be instaled
all other aplliances are ok
hope thats right, bad mistake!
Don't worry as far asI’m aware the tests are multiple choice so they won't be that hard
good luck and let usknow how it goes tomorrow.
Ok..... You asked for it!!!!!! (no, only joking :smile5🙂
What are the ventilation requirments for a single burner hotplate with a R/S boiler in a room measuring 1.5m X 2.5m X 2.4m where there is no excisting ventilation?
room sealed boiler no required ventilation unless stated in MI's
burner hotplate requires 50cm2 plus openable window if room is 5 to 10m3 which it is at 9m3
so 50cm3 vent required 🙂
thanks, feel free to throw any more questions my way, its good practice 🙂
i have 9 tutorials that i give to candidaqtes before their exam (not the night before TBH) but you are welcome to them, PM me with an email address,
remember to read the question properly, so with that in mind "DO YOU KNOW THE REG WHICH DICTATES THE USE OF TEMP CONTINUITY BOND?"
PS as a wee clue, if you need to look up the answer for this one it is gonna be a long day for you
REGULATION ACOP 10 .. 102
thanks
NO, NO, NO, NO ,NO,
READ THE QUESTION
THE ANSWER CAN ONLY BE EITHER YES OR NO, I DIDNT ASK YOU FOR THE REG I ASKED IF YOU KNEW THE REG.
1-0 to me, do you want another haha
yeah go on 🙂 i think you should only get half a point for that though
no 🙁 where did i go wrong ive just looked at it again but cant see it
Tha answer is on the same table (Flueless appliance ventilation) as the previous question.
J
2K
Central Heating Forum
Deleted member 120897
