K
Kevin Blackburn
Good morning all. I hope you are well.
I am hoping someone on here can help me.
I'm seeking some advice on the best way to quickly learn Electrical Fault Finding, preferably on Mechanical Systems.
I need to learn quickly as I had a trial day yesterday with a Gas Service Engineer who said that if I could learn about this topic by the next time we speak (2 weeks) I'd be pretty much the man for him and he'd take me on to train me up to become a Gas Service Engineer.
I've noted the usual: Understand how it is supposed to operate, Visual signs, Rule out functioning parts and list possible causes/faults, Most probable causes - prove it or rule it out, Determine cause, Replace & retest.
Also I have ordered a book called Wiring System & Fault Finding for Installation Electricians (5th Edition) and am now trying to learn how to use a Multimeter.
Any advice is greatly appreciated and will be used for the greater good 😀
Thank you in advance for your time
Well you will have to have a sound understanding of electrical systems and component function.
Also being able to operate test equipment and to interpret the results.
Youd also have to understand regs regarding unsafe installations incase what your working on isnt to standards.
Frankly id say not a chance in 2 weeks.
But I hope im wrong and you succeed.
I'd learn all you can over the next 2 weeks - he might just want to see if you're prepared to put some effort in.
What heating system have you got where you live ?
Maybe you can start seeing how all the components work on that as a start
obviously you can't start delving insider a gas boiler until you're qualified but if youve got a more traditional type system there's plenty to learn about without even touching the boiler.
(hint) - I'd be reasonably impressed if someone asking for a job knew how to test if a motorised valve was working
I`ve got no idea how old you are so I`d like to think that its a little test to see if your prepared to put some effort in over the 2 weeks otherwise he`s a idiot like ermintrude said
Thanks for all your reply guys. I'm 26 and he's a very knowledgeable man with a very successful company. He says it's a gamble for him to take me or anyone on as a trainee but he's looking for one so I'm at least in the runnings.
When I left, he said that if I could learn about Electrical Fault Finding on Mechanical Systems and learn how use a Multimeter I'd be the one he wants. We arranged to speak in 2 weeks and I said I'll learn as much as I can. I'm sure he doesn't expect me to know loads but as Blod said, I think he wants to know I'm willing to learn.
realistically I have about 3 months before he'd want me to start as have a baby due and he told me to take my paternity leave with current company as I'd get better money and wouldn't miss out on the training provided.
He seems very genuine so I am going to learn as much as possible. I believe in me and I'm hoping he will enough to take me on.
I was just hoping you guys could point me in the direction 😀
kevin, pm me your email address and ill send you anything i have that will be usefull.
you need to start at the basics.
1st thing to learn is safe isolation. Not the standard plumbers way of seeing if the lights gone out and asuming its ok. If you cant isolate something with an electrical supply in a safe way its not worth learning any other tests.
There is also a test of competence to work on such systems.
You havent stated exactly what the systems are, which will determine the level of competence required.
But it you are looking at fixed installations supplying such appliances and the appliances themselves you will need to prove competence.
How can you tell the appliance is earthed correctly .
How can you tell if the earth is satisfactory and what test is right (Tn Tns Tncs) and able to carry a fault current. How can you tell the fuse or other protective device is operating correctly.
How can you tell you have correctly isolated the appliance prior to work and physically test it is electrically dead - removing the fuse is not enough.
How will you do this without calibrated equipment.
Im being devils advocate here but these are real and everyday considerations before you even start work.
Competence comes typically via a level 3 and 17th and part p (as you stated electrical work mainly ??? )
If you cant do that then you will be breaking the law.
As I say I do understand you are going to train but until you have competence you possibly shouldnt even be touching stuff.
Some of the seaward and alphatec gear I used to use would take a week to understand the machines full capabilities
You possibly need to explain more of the type of work.
I dont know many gas engineers who dont understand the full goings on electrical wise inside boilers so does he want you for sorting out the fixed installations ???
Again, thank you for your replies. He says he wants to train someone up to be a Service Engineer and if I can learn as much as I can about Electrical Fault Finding it would put me at the top in his eyes.
I am going to reread the section on Electrical Principles from my C&G 6035 Plumbing book and then learn how to use a Multimeter. That's my plan for this week. Next week I intend to learn the firing sequence of boilers, in thinking if I know the sequence of how it works it will allow me to work out where it's wrong. Also I want to learn as much as possible about the workings of components in boilers.
I really want the job, more money and a more comfortable life. I know I can do this and if I can't, well, I only have myself to blame.
thank you 😀
i would work on 'y' plan wiring, volts, ohms tests and continuity & common sense before anything else, afterall, he is doing the training right?
he wont let you loose without direct supervision and training around a boiler on your own anyway.
2 week gas engineer!!
also, the sequence of boiler workings may impress him?
