Jennie
283
45
28
Hi all
I'm a female plumber, so don't much encounter a urinal (especially as I usually only do domestic work).
I've been sent pics of something that has broken in a urinal - it's the flush valve. As I gather, the urinal cistern fills up gradually, and flushes through every so often.
A link to the correct new part to buy and fit would be massively appreciated.
Thanks everyone,
Jennie
https://www.NoLinkingToThis/p/thomas-dudley-ltd-bbs-automatic-urinal-siphon-6-82mm/8559r
1/2 inch is the most common. Measure the height
Bear in mind if you fix it they'll call you when it's blocked and whether you're male of female it'll make your eyes water.
Reactions: Jennie
