hi all, now im oftec only so dont have much to do with solid fuel. however the estate to which i service and maintain has a tenant who is basically a bodger. he told the estate that i thought it was a good idea for him to fit a solid fuel burner and rip out the oil system. so now im meeting with the land agent and tenant to discuss the system. From servicing the boiler i know the layout of the system and told him in no uncertain terms the system wasnt suitable to be put onto a solid fuel system. so basically a little advice from someone who fits / installs solid fuel would be good ..
The existing system has a primary circuit of 22mm then 15mm to rads. ( i presume not suitable for solid fuel ? )
There is an existing stand alone log burner in the kitchen, to which the tenant says he will rip out, replace with a hugh solid fuel boiler connect to heating circuit a walah job done !!
Firstly im sure he shouldnt be doing this work himself, (as hes clueless, not incompetant)
so , does the chimney need to be lined ? does the system need a heat leak rad ? is an injector tee part of the requirement ? what sort of fire plate / protection is required ?
ps, im not wanting to install this system, just enforce the reasons why it isnt a suitable option.
