Aug 13, 2015
288
16
18
Hi, I have been doing a bit of maintenance on the system in a recently purchased property. It has been flushed numerous times for various types of work, from removing existing rads for flushing to fitting new rads, and fixing obvious leaks around the cylinder (all joints PTFE wrapped and compound applied).
I will be having a new unvented system instaled in the next 2/3 years once other works have been completed - until then i want to get the rads and corresponding pipework to a level where it is safe and efficient. As the carpets come up in say 6 months i will be lifting the floor boards and checking the pipework further with a possible view to changing some of the 8mm to 15mm to ensure future reliability (and less chance of blockages). In the interim I have added cleaner after the last lot of works a month ago and am about ready to flush and add 2 bottles of inhibitor to get me through the next 6 months (possibly much longer if i decide not to disturb anymore pipes).
The system is 13 rads with a combination of 8mm and 15mm pipes going to random rads/towel rails. The house is 4 bed with the 20 yr old boiler mounted in the kitchen at the far end of the house, whilst the cylinder, diverter valve and pump is more centrally located on the first floor.
I have refilled the system quite a few times now and after endless tries i can still hear air going through the return pipes into the loft, even now after a month - is this normal that i would be bleeding the system probably once/twice a week? I always start at the bottom working the furthest rad from the pump as opposed to the boiler, i then move upstairs doing the same but attacking the rad above the boiler first as this is the only one that normally needs bleeding and is the first to heat in the circuit (i then do all the 15mm piped rads followed by the 8mm's as all rads are a similar distance from the pump). lastly I release the screw on the pump and let water flow for a few minutes before closing the screw and firing up the central heating circuit until the rads are warm, then the hot water circuit until the water is warm. We don't use the hot water option a lot as we have an electric shower for now and dishwasher - the rads all heat without issues so no blockages and the air from the rad above the boiler doesn't smell eggy so no massive corrosion issues. Since the cleaner went in the rads have been used daily too... there are no leaks on the rads hot or cold (or any other visible parts of the system), i have cleaned the header tank of the brown sludge (which hasn't returned) - my only thoughts are tiny leaks below the floors that i can't yet access (most likely downstairs as no ceiling leaks visible).
Worth also noting that the system hasn't really had more than a month of use before me working on it so this next fill will be the longest time it has gone.
Can anyone offer any help please? :teeth_smile:
You mean the overflow pipe going outside? I can assure you the vent pipe from the system is at the bottom of the tank and is the very same pipe that feeds water into the system, I've witnessed the bubbles coming up when the system is venting.
I will leave it alone after the next flush as mentioned, I was asking advice on anything else I need to think about regards the trapped air.
It sounds like your pump is on the return to the boiler? Is the cold feed also on the return and the vent on the flow if it's old skool? You mentioned pipes in the roof so not far below the F&E tank?
Not knowing the exact layout of your system it sounds like the pump is drawing in air, possibly through rad vents or auto air vents if you have them, could well be the pipework in the roof is actually at negative pressure due to the height and the pump position.
I would look at resiting the pump onto the flow after the boiler with the cold feed and vent connected to the flow between the boiler and pump, that way the whole system is then under positive pressure and shouldn't draw air in.
Looking at it i think the cold water feed and vent are both before the pump, the FE tank is above the immersion cupboard approx 3 meters up, the only pipes going to this are the 2 you can see in the picture and the overflow. Knowing what i have to work with space wise there wouldn't be an easy way to put the pump before this manifold as the 22mm pipe disappears beneath the floor to a very cramped area - near the boiler is also extremely tight leaving no place for the pump either.... This will obviously all be addressed fully when the unvented and new boiler get fitted at the back of my garage (behind the kitchen wall)
You need to get some air vents either side of the 3 port valve in the picture,trapped air has nowhere to go as it is
Your pump is on the flow from the boiler, if after fitting air vents problem still persists,combine the vent and cold feed (tee the vent pipe into the cold feed)
Two faults: as mentioned above you need vents to get rid of the air around the 3 way valve and there also appears to be an unvented high point on the return from the cylinder. Assuming the cold feed and vent are the two pipes coming in on the suction side of the pump I don't think any changes are needed there as the whole system should be pressurised by the pump.
As a temporary bodge, you could crack the compression joints either side of the valve to let out any air and see how that goes.
Thanks Spark - I've continually monitored it the last few days and it seems to have subsided massively. Hopefully that's the problem solved for now, although I'm going to have to drain this again soon to get the cleaner out (cheap Screwfix stuff) and the Inhibitor in.
I've just had my plumber visit - he thinks it'll be ok with the cleaner until I'm better in a few weeks as its only cheap 'no nonsense'. One thing I forgot to ask - is it worth adding inhibitor as I'll be working on it again March/April when the carpets come up, following his advice and changing to 15mm or 10mm (if 15mm won't fit) from the 8mm for the 6-8 rads that are running it.
Always put inhibitor in. Only a tenner or so. I'd probably leave the cleaner in also for a bit. It's only active for about 3-4 weeks anyway.
