Re: As the employer what questions would you ask service/breakdown engineer at interv
I was 🙂
thats i only ever did 8 appliances max.
The only thing that's on your side is there is a a lot of new condensers in council houses that will only require a strip down if the FGA fails. And even then it may just be the gas valve needs adjusting.
Plus, a lot of properties are In the same street. So travel is at a minimum.
Even so, I still only did 8 🙂
Surely you cant be expected to give each appliance a strip down and clean?
I was 🙂
