It's not just the length of the pipe which is important. You have to take into account the flow rate, which depends on the size of radiator and the temperature differential. For example:
Resistance of 18m of 10mm pipe connected to a 2kW rad with a 20C differential is approx 0.58m, with a 10C differential it is approx 1.94m. The flow rate has doubled so the resistance increases by four times.
Upload your rough calculations and I can take a look at them.
I won't embarrass myself as they are obviously wrong and too basic. It's plastic pipe too which might make a difference?
Won’t the flow go straight through the bypass valve as it is on its max setting now and it would have the path of least resistance than the rest of the system?
Are you going to use both the tees and the hydraulic separation I was under the impression it’s one or the other with the tees being the cheapest?
Not wrong just has advantages / disadvantages = smoother bore less fitting but at the end of the days it is a small pipe which limits the heat flow to each rad to something like 3 - 3.5kW but each is fed directly from a 22mm manifold.
To highlight a commonly held misconception that a differential pressure automatic bypass valve works well with a proportional pressure pump (e.g. Grundfos Autoadapt), please note that Grundfos does not recommend that the two are used together.
