Listen you lot need to calm down I'm doing a favour for someone because they're getting the cupboard re plastered where the wiring centre was. I appreciate your concern but I do know what I'm doing I'm just putting it back how it was. No one is going to get hurt. I've put it back this morning while on the phone to my colleague and it all works fine. The old British gas apprenticeships were actually very good and two of the best plumbers I know have worked for British gas when they started out. its like Lego really I wasn't in college the day they did wiring centres. All I wanted to know was should there be a pump in the system... I'm not a pretend electrician and I don't really appreciate all the insults. This always happens in forums people getting lemon cos they're hiding behind a computer screen. Anyway thanks for all the really really useful advice and help still no one able to answer the pretty simple question. Next time I won't bother. Jeez
Mate, your question was answered three or four times. The pump is inside the boiler. You apparently don't know the difference between a shower pump and a central heating pump, nor between a direct and indirect cylinder. These are alarmingly simple things that anyone working even on the fringes of heating systems should know. Are you surprised that people were concerned about your ability to do the work safely?
If you are not a pretend electrician then you must be qualified. If it was simple to you then you wouldn't be asking!
It could still work but you have just lived up the cylinder. Things like this have happened, hence why you shouldn't touch it if you have issues. Go on a free course and find out how it all works before you mess in soneones house.
There are many people that bodge because a little knowledge is dangerous. You should see some of the gas jobs we come across because people think that they know what they are doing and clearly dont. You can't see most electricity, you can't see carbon monoxide. We are only looking out for your back.
But some people wont listen, they think they know best ! probably been looking on u'tube
This one is very simple, if you don't know, then don't play. Fine, you might know a bit about electrics, but that won't help you in this. I know a couple of sparks who've been in the trade for years but won't wire heating systems.
Won't be much of a favour if you fry the pcb on the boiler.
Its done. Everything's working fine. Thanks for all the really useful advice and help. Turns out its just like Lego. As I said before I wasn't in college the day they did wiring centres. No ones hurt no need to call the police everyone can relax.
Glad you got through this, but you do worry me. Did all your continuity checks ZE, ZS PFC work out ok?
I'm not an electrician so no I didn't but the sparky on their job will be doing all that. I'll PM all of you a photo of the test results then you may finally be able to sleep. It really isn't a big deal, I've seen some plumbers out there that can't spell and look like the missing link, and they seem to be able to wire it up ok. Being a plumber doesn't require MENSA membership and some of you need to pull yourselves out of your own arses. Wages for plumbing these days are bloody terrible anyway I don't envy you. I do my own plumbing and for friends and family so they don't get ripped off by jumped up labourers with a spanner. I'm a refurb contractor and I know enough about every trade not to get mugged off.
HAHAHAHA I was the one answering my own questions here, no one helped one bit. I told you lot it was a y plan. I worked that out because of the components in the system, and the fact it had a v4703 mid pos valve. All I wanted to know was whether every system needs a pump, I thought it might have been under their floor or something. I still didn't get the answer, someone even said "a y plan won't work without a pump". I wish I'd never asked to be honest. Thanks though for all the really really useful advice.
You got the answer 4+ times. You really havent got a clue! You say that plumbers dont have to be mensa but at least be able to read what others are saying to you!
Are you part P? If not why are you wiring it anyway? What happens if something goes wrong in between the time you finish and the sparks test it and burns the house down. I bet they wont appreciate that favour!
You don't need to be part p if you let your LBAC know you are doing the work and they check it off, check it out, more scaremongering. High horse needs a break I've got a high trough he can have a drink out of.
Yes you did get the answer ! the pump is in the boiler, its that you did not understand the system you were messing around with !!Your so smart how do you think the water & heating work with out a pump. Its a bit rude to say that you got no help, next you will be bragging how you sorted out this fault, and how no one on this site could not sort it, I think you have just been very lucky that you did not cause any damage.
simples.
no pump.
So simple that you only now found a pictures of it and you were looking for a pump that didn't exist?
I'm glad you have it sorted but you really don't seem to understand what's being said here.
I'm glad you do all you're own plumbing work. So does this guy:
Simple as the diagram shows or should we call it a basic sketch which if you take for gospel would never work. Further more with the electrical work, the EWR require you to have sufficient experience and knowledge to carry out the work safely and not cause danger to any person. Basically qualified and tested, not just wired by numbers.
If you don't like the replies you get, you shouldn't be getting too arsey with people you might need more advice in the future.
I have Part P but not a load of experience so usually have someone giving me pointers when i'm doing any wiring. People were trying to help and you were told where the pump was.
Also sounds like you watch too many Danny Dyer films.
Reactions: 4 people
UK Plumbers Forums
Deleted member 120897
