M
Masood
Why are we still feeding the troll lads? We all know that he knows diddly squat - the questions he asked give that away. Now he's just on a wind-up.
Yes your right there, heard enough now, Tamz hit it on the head on thread 2.Why are we still feeding the troll lads? We all know that he knows diddly squat - the questions he asked give that away. Now he's just on a wind-up.
Guys don't worry I've worked as a sparkys mate before I have a fluke tester and a live wand too. I'm perfectly safe just not an expert at wiring centres. Thanks for your replies though. S noo what does the 3 port valve do if the boiler switches between heating and hot water? Essentially the question I was originally asking is why in all the wiring diagrams I look at does it have a pump in the system, and can I just omit it and connect up everything else.?
It is not pumped by the boiler, a y plan doesn't have to have a pump. I've worked all this out with the ex-british gas plumber you were ridiculing yesterday, after none of the so-called experts on here could offer up this simple advice.
I give up. The pump is connected to the flow and return pipes from this system boiler and are connected to the heating coil in the cylinder. The boiler doesn't have water in and out pipes, so how can the pump in the boiler push water to any taps? Have you thought about what you're saying. Experts still telling me there's a pump in the boiler. The pump in the boiler has nothing to do with the hot water, its just for heating the rads and/or cylinder. Are you saying that the central heating water that's been going round the rads suddenly comes out of the tap. The two circuits are completely independent.
Can this thread be locked before people start calling this bloke a c*** or a p**** or a bell end. Oh that ones ok! There's a pump in the boiler. There's a pump in the boiler. There .... Is ..... A..... Pump..... In..... The..... Boiler!!!! A pump! In the boiler! It's in the friggin boiler! You've been told countless times. Now sod off and stop antagonising the good folk on here.
Quality rant! 🙂
