L
LesleyH
Hi, from a new member…
I hope someone can give me some advice here. We are in a mid-terrace, connecting with our neighbour only on the first storey, as the ground floor is separated by a gunnel. She is 94, lives alone, and has been frightened by intermittent, very loud rattling/banging of pipes, which she and her visiting family members say sounds like a train going through the house. It happens only during the day. They are blaming us, as we had a faulty boiler last year that made a rattling noise but that was replaced right away and we have since had no plumbing issues. Our plumber says that everything is fine but the family will not believe this and are threatening some sort of legal action.
Her house was built just after WWII and ours is slightly newer.
A builder friend who once had a similar problem with his house and the adjoining one, suggests that the noise is being caused by the Water Board changing water pressure and thinks that the neighbour’s stopcock needs to be adjusted. That was his solution and he said that it solved the problem. Does this sound feasible? I know nothing about plumbing but need an explanation for the family, who insist (in a very shouty aggressive way) that it’s our fault and we “need to sort it, it isn’t rocket science”. We are feeling quite intimidated and since our plumber says there is nothing for him to fix aren't sure what to do next.
i would ask your plumber to give you something in writing say no problems in your house and send them a copy i definitley wouldnt be worrying about legal action they cant do much to real nuisance neighbours let alone a few noisy pipes
I looked it up , it said something about fish. When I was a kid we could hear trains along the now disused tunnel under our house, this gunnel/tunnel knows more that it's letting on.
Thanks very much for replying, Steve. We are getting a letter from the plumber and I was also hoping to be able to give them a possible explanation so that they can get it fixed for her. I was pleased to hear about the stopcock idea but not sure if that is a viable thing...
Thanks again 😀
It can be fault of a stopcock turned down too much, or the washer in it hard.
Or it can be a ballvalve usually on the cold water tank in attic (if there is a tank there).
I would consider getting another plumber in that you are also confident with and get his opinion plus it in writing. Then put copies of the letter in an envelope together with a letter asking them what is convincing them that you have noise coming from your property and suggesting they get a proper professional plumber to check their property.
Just a thought, - You say the noise only occurs during the day?
Why not turn your stopcock fully off for one day (however inconvenient this may be) and see if noise still happening that day in neighbours? DO NOT tell them that you have turned your stopcock off! That way if they still complain you can tell them to sod off
Reactions: 3 people
Have you heard the noise in your house?
Have they had someone in to check there house?
If they haven't then encourage them to take legal action and waste there money.
If you have had yours checked then it's not your problem tell them to go fourth and multiply and if they keep threatening you then you will seek legal advice.
Reactions: 2 people
