Basic Tools
View the thread, titled "Basic Tools" which is posted in Plumbing Tools on UK Plumbers Forums.
H
Hannah
Which is the best place to get good quality basic tools from e.g. Hammers, Pipe cutter etc?
I'm getting myself a tool box together 🙂
Hannah x
Don't agree any more! I'm a hilmore, glm and c35 always have been. Two apprentices have robo / plumb center and they always producucing perfect bends. Bad tradesman blames his tools!
Yup ...but is a true excuse 😉 ...never have been able to get on with them....If you were nearer scotland have a cheap bender I bought before i got my new hilmor 🙂
Best bit of kit is a decent belt, to avoid cracks on display, esp one with a thong! Also old tools were better quality than some of the tat on sale now! My best buy to date was the contents of a van sold buy a lad who just gave up! £90 for over £800+ of tools and spares, still working my way through his box of 28mm ef parts
WOW! You dropped on good then, I hope i drop on someone that sells most of the equiptment! 🙂
I would and do frequent ALDI there is no guarantee that what you want will be there
but when it is its really quite good stuff and cheap. All the electrical stuff is Black
& Decker re-badged centralheatking
Hannah x
Must admit I bought a wall chaser from aldi about 7 years ago and it's still going strong. Not to be used in occupied buildings tho 🙂
Lets change the game here!!
which of the more established engineers here. Have that second tool bag with the early basic tools they had. Which is now gathering dust and taking room in their lock up.
could kindly donate to hannah the spanner 🙂
I think you need to keep up lol.
hannah does not do nuts yet. so what good is the spanner to her? I reckon when she gets 2b 23, she will start doing nuts. Then a spanner will come in handy.
What about all the other noobs? Hanna seems to be getting a lot more tlc than the others do? I thought about offering tools but but unfair on the other noobs? I give most to own apprentices!!
personaly i like the CK tools pump pliers! bahco adjustables , and i have a fantastic set of draper expert screwdrivers, but just bought a set in local travis perkins the other day of screwdrivers with a red, green and white handle with a printed welsh drgon on!!! look fantastic !!!
I have bahco spanners, they are like an extension of my hand, i feel lost without them. monument pipe slices, better than rottenberger. a good level and a permenant marker and pencil are a must!
Bahco spanners are just the best, no other can match it, if you get 8inch wide jaw spanners they cost but your set for life, ive had mine for 3 years now and I dont know what I wouldve done without them!
im an apprentice doing level 2, i try and buy one new tool every week and if i don't i put the money away for something more expensive, this is what i have in my bag up to now.
monument pipe slice 15,22mm
3 bacho spanners, 2 six inch and an 8 inch
pipe cutter
3 spirit levels
tape mesure
screwdrivers and an electrical one
bacho grips
bosch multi drill bits
bosch spade bits
back nut spanners
tap spanners
plastic pipe cutter
Stanley knife
junior hack saw
pipe bender
super fire 2 blow torch
Bosch drill
makita impact driver
makita drill,driver
makita radio screw fix have deals on with these three i think i paid something like £150
wood chisels
pliers
wire cutters
small rubber hammer
pipe cutter
3 spirit levels
tape mesure
bacho grips
bosch spade bits
back nut spanners
tap spanners
plastic pipe cutter
Stanley knife
junior hack saw
pipe bender
Bosch drill
makita drill,driver
wood chisels
pliers
wire cutters
small rubber hammer
Very dedicated apprentice! Well done! Uve been robbed of your radio though, makita DAB radio came out and was £120
pipe cutter
3 spirit levels
tape mesure
bacho grips
bosch spade bits
back nut spanners
tap spanners
plastic pipe cutter
Stanley knife
junior hack saw
pipe bender
Bosch drill
makita drill,driver
wood chisels
pliers
wire cutters
small rubber hammer
well done.
now go out and buy an SDS Drill seing as you are on the War Path:shades_smile:
If you have any spare cash for a small extravagance then try to get a 28mm pipe slice. It will probably only be used once in a blue moon but by heck when you need one you will be really glad you do have it in your kit.
28mm will come into its own when removing old gravity primaries to DHW cylinder. Never leave behind that which can be loot (11th commandment )
I have found that it is worth waiting a bit longer to get better tools, in the long run it is cost effective as usually last a lot longer and also saves time on jobs as they usually are more robust and don't fall apart half way through a job. Also it is worth keeping a eye out on ebay and amazon for good tools, as I have picked up monument pipe bender new off amazon for £17 as some stores clear there stock.
Hope this helps
good luck
Havn't read the full thread but......
I can do 50% of my simples jobs with the tools on my tool belt
Dumpy adjustable spanner, pump grips, posi and flat 4/5mm blade screw driver, 2mm electricians screwdriver, snap off blade knife, 5m tape measure (lol) total cost £20 tool belt £15 I kid you not
then I can do 80% of my jobs with a tool box, the number of items I hold in that box are too numerous to mention but if you want to take an inventory of the tools I carry then will be happy to help
The other 30% of jobs take a car load of stuff that's the nature of the beast
Russ
PS welcome to the world of the building trade I love it and am a bit of an anorak but don't let that you hold anything against me, I hope you find the work varied and interesting, I do and I've been doing it for most of my life
I have banned snap off knives after one of the lads nearly lost a finger cutting a sheet of plasterboard when the blade extended. They are all junk and too dangerous as the blades never lock into position securely.
No problem with a stanley.
Hi Tamz
Yeah know what you mean but Stanley blades are too short to get into silicone sometimes and as the tip keeps getting blunt too expensive to keep changing
Also the cheap snap off blades have a real thin body whereas Stanley are real fat, alright for cutting plasterboard, but as a plumber I don't get to cut plaster board real often.
As a plasterer I cut plasterboard all the time and have never cut myself (erm..........) careful with that axe Ugene as the Pink Floyd lyric once advised us
Russ
Hi Tamz
Russ
Must be some real rough silicone job if a stanley blade is too short. .......
I agree with tamz them snap off blade jobbies scream art class to me, certainly not something a pro should be using
Oh and them snap offs retract back into the tool so they have no sharp bit when not in use
Do the Stanley have a blade cover, and if they have a retractable blade the blade be not able to be locked as it contravenes the law on blades and knives (I think)
So how do the retractable stanleys keep in the "out" position?
I feel so strongly against them it is actually a sacking offence to have one at work. Its me who has to deal with the paperwork and mop up the blood so it is not happening.
Snap offs are the weapon of choice for the blade man at the dancing. Easier to conceal and the 4" blade will hit something :shock:
Reply to the thread, titled "Basic Tools" which is posted in Plumbing Tools on Plumbers Forums.
Hannah,
plumb_know,
