Bathroom conversion gone from bad to nightmare!
View the thread, titled "Bathroom conversion gone from bad to nightmare!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
🙂🙂🙂🙂 that will be expansive bathroom according to this string , if it was for boiler change or full ch install will travel but for this .....better off local plumbers job
I might be way out because, as Tamz suggests, how long is a piece of string but a guess is 10 days (£1,750) and say £500 for materials so £2,250.
This, though, is a real finger in the air type of figure but if you were wondering whether it should be nearer £500 all in I'm not sure you could find anyone to do it for that price and expect a reasonable finish and if someone charged you £8,000 I think you'd only be wondering about the price as the quality of work would, presumably, be perfect and so you wouldn't be hear telling us of your nightmare (which it is).
I hope you get sorted soon.
£1800 sounds around the rite price i would say i just cant explain no more how these shocking tradesman wannabes get away with this you said hes got your house key too!
The plumber sent his minion this morning. He took off the wall hung pan and we confirmed that the nuts on either side of the concealed cistern frame (which holds the rod that the wall pan hangs on) are loose - so loose in fact - one was about 5 inches away from the frame.
The plumber is blaming the minion for tightening and loosening the rod - and making the nuts move away from the frame. This is a SIAMP BCM350 frame.
He insisted that the minion should put his hand through the hole (for the soil stack) and screw the nuts back against the frame on either side to dead lock them.
The wall plate has been over-tightened (due to the loose nuts) and now we've noticed that the bolts on the wall plate have cracked the thermaliteMy question is: If they insist that they can do repairs without dismantling the cladding and tiles from the concealed box - are they talking utter rubbish?
When exactly should I put my foot down and say - enough is enough, just give me my money back and I'll get someone else to do a proper job? Marcol SIAMP 002.jpgMarcol SIAMP 003.jpgSIAMP (7).jpg
Oh and behind the wall hung pan, the plumber has piled on a massive amount of silicone to "seal" the leak - which was the result of the loose nuts, making hte wall hung pan move, and so the soil stack membrane was twisted and should they even do that?
Sealant and twisted membrane on Inlet Pipe of Pan Small.JPGSealant on Inlet Pipe of Pan Small.JPGSealant in Soil Stack Small.JPGHere are the photos of the silicone sealant. You'd think he owns shares in a silicone sealant company from the amount he used!
Sorry to trouble you again guys - but the plumber sent his minion to rectify the faults and I just need to ask one question - when he took off all the silicone sealant from the soil stack (drain pipe) that is connected to the back of the wall hung pan, the soil stack pipe is now held onto the few inches of wall hung pan pipe by a rubber membrane - and the whole thing wobbles.
I've uploaded it onto youtube - to give you a better illustration.
YouTube - Soil Stack Wobble.MOV
Please help.
Which fitting? The soil stack? Could it be that since SIAMP is made in Monaco and the width of the soil stack is 100mm, the Euro Wall Hung pan has a drain pipe that is perhaps 110mm, the two of them need some kind of adaptor?
They way you are holding it the connector will move. Push it back hard against the wc and there will be little movement, perhaps 5 - 10º deflection. It is the way they are made as they are made to fit a range of sizes.
As widfire said, the wc spigot may be undersized which will give more movement.
Have a read at this link and you will see what i mean (these are about the best brand of connector imo)
WC Connectors - Multikwik
You won't be long in finding out if it seals when it is flushed.
Hello all,
Right at this moment, the whole thing is in the hands of the small claims but I do have a question:
Eversince the combi-boiler has been "tampered" with by the plumber and his side-kick, whereby I was billed for a Combi-boiler servicing and a new radiator installed (albeit upside down), the water pipes now give occasional tremors - shuddering - even though no one is using the taps or the central heating isn't on.
So what do you think is the problem now? We did bleed the radiators - hissed alot and the safety valve of the combi - boiler shot out and left a black spot on the ceiling...
Would appreciate any advice.
Probably air. Think you should get a recommended plumber or heating engineer to have a look, will save you more money and pain in the long run. Just a wee word of advice, if this is all going to court, keep your info private and don't disclose it, moreso on the internet or it could backfire on you in court.
I don't know - most likely. What do I do now? Pressure guage shows 2 bars I think. The sidekick actually left the key in the combi-boiler (when he finished) and he had to come back the next day to take it out - he gave instructions for us to do it - but we couldn't - so he came back - tugged at it with all his might - and it wouldn't budge - then he fiddled around for ages - and finally he found that if he turned it at a certain angle - the tabs in the key returned to the holes where one can pull it out easily without fighting with the whole thing.
Just now read the whole thread!!!
This is appalling
Even if you get your money back you will likely be a loss due the state of everything
Find a local tradesman and ask him to pop round for a free quote and the you can take that to the small claims court
Reply to the thread, titled "Bathroom conversion gone from bad to nightmare!" which is posted in UK Plumbers Forums on Plumbers Forums.
wildfirejc,
Plumbstar Tom,
