L
latza
I've got a baxi 105e boiler.
It's flashing 60 degrees which is a low pressure / pump fault. I've found that the pressure switch on the 3 way valve isn't being made. The plunger isn't coming high enough.
I've replaced the diafram and cleaned the valve but it's still the same.
If I make the pressure switch with my screw driver the hot water and heating both work
Any ideas?
Any ideas?
