G
garyrobinson
Hello,first time on here.
Firstly I am GSR and if you want I'll post my register number and licence number.
I really need some advice,I was called out to the above boiler today which had a flame failure neon flashing,it Isn't the pcb because the boiler fire's up and it can stay lit for up to 3 hrs then it switches itself off and starts flashing.I removed and cleaned the condensate trap checked the Ch thermister the gas valve is fine and I can't think what else it could be,there are no MI's and I've only been doing this kind of work for about 6 months,could someone help me please.
hi welcome to the forum you need to contact admin bud as gas works not discussed in open forum
Hello Gary and welcome to the forums.
Sorry mate but this will not be discussed in open forum.
I need you to increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - http://www.ukplumbersforums.co.uk/users/8668/ or Redsaw - http://www.ukplumbersforums.co.uk/users/2718/ who will check you and then give you access to the gsr private forum.
This isn't getting at you but is to protect have a go heroes from themselves.
