baxi megaflo system boiler any good?
View the thread, titled "baxi megaflo system boiler any good?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
B
Buzzfan
Hi - does anyone have any experience of baxi megaflo system boilers? i am used to their cylinders, but not the megaflo branded system boiler - any feedback anyone?
There's nothing wrong with The Baxi Mega Flow. Sure a decent Vaillant or Remeha will probably be be better though
Thanks for the replies.
After logging on to the Which consumers fourum, i found a survey of several thousand boilers - interesting to see which names they said avoid!
The Baxi potterton breakdown rate was about 5% higher than the vaillant or WBosch, but for a saving of £ 300 (£ 700 for boiler/flue vers £ 1000), I've decided to take the gamble!
That will not be a statistically valid sample as only those people with a faulty boiler will bother to reply.
So you see the following results: Brand A 100 faults, Brand B 500 faults. Therefore Brand B must be the worse.
But Brand has only sold 1000 boilers and Brand B 50,000. So the failure rate fro Brand A is 10% and for Brand B 1%
not really - they list the percentage of each make separately so it is fairer - these were the results:
Alpha - 64 sampled, 45% breakdown or other problem
Baxi - 250, 45%
British Gas - 203, 45%
Ferroli - 34, 44%
Gloworm - 287, 42%
Halstead - 30, 53%
Ideal - 163, 46%
Keston - 34, 79%
Potterton - 188, 38%
Vaillant - 426, 29%
Vokera - 34, 32%
Worcester Bosch - 927, 32%
Oddly, Ariston werent listed - I've had 2, both failed. And 2 Pottertons, both fine!
The average failure rate is 37% - an astonishingly high figure. I've installed about 200 air-conditioning units, barely 5 have had failures.
Baxi - 250, 45%
Ferroli - 34, 44%
Gloworm - 287, 42%
Halstead - 30, 53%
Ideal - 163, 46%
Keston - 34, 79%
Vaillant - 426, 29%
Vokera - 34, 32%
Thats because when you fit an aircon unit its virtually out the box and plug in Built and tested before dispatch in a factory somewhere your not connecting to old pipework and controls
i wonder what the figures are for breakdowns being cause by poor instals rather than actual boiler faults
this would go some way towards ferollis poor figures as a lot of those are sold through the sheds
How many Baxi, Potterton or Vaillant etc boilers do you think there are installed in the UK? To conclude from a sample of 250 that 45% of Baxi boilers will break down is ridiculous. The sample is too small to be statistically valid and the method of sampling (just Which? members who bother to take part in the survey) is suspect. If you want to know the true failure rate you need to ask the manufacturers, who will have the info for their own benefit.
iv fitted plenty of baxi/ pottertons (basically the same thing) and they havent been too much trouble. No more trouble than worcesters have been. And your right about the cost, and theres no way worcesters are worth £300 more.
Now im a loyal viessman fan.
I,m a veissem fan because of 5 yr grtee ,but worcesters are great boilers and theres not much in price between worcs and veissem
like most boilers they are great when they work and i've fitted a few megaflo boilers and they seem to have the same range of faults as most of the other HE boilers out there i.e fan failures, spark failures etc.
I have customers with gas boilers over 25 years old that I still service and change the odd small part on but i always wonder how many of these will still be around in 20, 30 years time !!!
Reply to the thread, titled "baxi megaflo system boiler any good?" which is posted in Boiler Advice Forum on Plumbers Forums.
Buzzfan,
MJPH,
