hi all
fitted a baxi solo yesterday with a new room stat everything was working fine before i went as i had to commission the new boiler ! customer set the programmer after i left then a few hours later the boiler has no power ? i have checked the programmer which switches the hot water and heating on but there's still no power to the boiler or the zone valve ?
i rang baxi who advise to hardwire the boiler and pump to a plug check they work ok which they did.
would it be the programmer thats not switching the power to the boiler and zone valve or would the zone valve be faulty ? everything works fine the room stat has power the cylinder stat has power the pump is wired from the p/f on the boiler terminal so if the boiler has no power nor does the pump
any advise would be good as it worked fine yesterday now i scratching my head on what the cause of no power and how it fix it ???
thank all
thank all
