hi all,
i have a problem case and as im new to all this i could do with a little help.
i got a call out as no heating but hot water works on a pumped y plan set up. checked pump works but its a little/very hot. pipes either side of pump are hot. but no heat reaching radiators. bled radiators no better. boiler switches off after a few minutes via stat and pipes before and after pump go cold but pump stays running and very hot.
1st thoughts are pump not enough uummppff but on setting 3 anyway so cant turn it up.
2nd diverter valve.... problem is....
diverter head cannot be moved manually as there is no spring resistance however when heating turned on the heating sides gets hot. when hot water turned on both the sides get hot.? cannot hear motor valve moving when selecting either so thinking the valve is stuck in "both" position but then why on heating only does the heating side get hot? but hot water does both sides?
i dont want to make myself look stupid at customers house.
my 3rd choice could be a faulty stat (i know diverter is still a problem too) shutting off early but that seems to be new on the boiler
any help would be appreciated. thanks for looking guys and girls
