solutions
1,413
628
113
The Green Grass over there.
Ok where to start. Called to a customers home to attend a Riva Advance he with an intermittant fault. On viewing the combi for the first time alarm bells start chiming. Theouter covers are off and the inner case screws are slack and the case is not sitting tight home. It is clearly drawing air from the room it is igniting but burning rough and ignition is with a bang. I close the case tight and the ignition sequence fails to ignite the burner. Fan is spinning up pump is turning. I suspect blocked flue so shut it off and go check the flue outlet. Find that the concentric 60/100 standard flue which extends beyond the wall face by aprox 340mm is crushed flat to the depth of the internal exhaust tube blocking almost all of the lower half of the air intake. I point this out to the customer and advise that it is likely contributing to the fault. Eitherway it needs sorting. So I change it for an undamaged biasi horizontal flue. Case back on. boiler fires its noisy like the fan is hitting a certain vibration or resonance its like someone blowing across a beer bottle neck and It still burns rough. I analyse it and it peaked at 6000 ppm co. I revert to manufacturers specs and follow the guide to set the gas valve. I get the co2% to sit at the required 8.8% on minimum burner but the co is still high. The co2% is out of range on max burner. Also now the gas valve has been adjusted the ignition sequence fails cycling through sparking till it locks out. I have had the burner out and it is fine as is the primary heat exchanger and air intake duct to the fan. I am going to call biasi in the morning but im not holding my breath. Anyone here got any ideas what mightb e the cause. The only thing I can think of that I havent been able to check is fan speed.
Can't discuss gas in public forum. Advice readily given in gas safe forum. Need to have 10 posts plus be GSR. Contact admin .
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
