Hi folks,
Really never thought i would get this much response from my post. When i posted i think i was angry and ranting and just wanted to share with someone.
So many many thanks for the comments and the great advice given. If there is a paypal link i wouldnt mind donating if you guys have one as it is a great site !
We managed to borrow a few heaters so the house is fine and the kids have those onesies so fine in bed at night.
I have a thing about things being plugged in at night so last night i knew the temperature was dropping so i got up early and put the heaters on. Thank god because it was -2.
Kids are at school during the day and we are both out at work so although not ideal we are managing.
Its funny because it makes you realise how lucky we really are with the poor souls out on the streets and families and old folk who cant afford to put the heating on. It was also a great topic to talk to the kids about.
A few posts up mentioned that cheapest is not the best. I agree but the guy doing fitting it is doing us a favor and he is a local well known heating engineer. I really think the guy had sympathy for us as he said he wished he could do it sooner and he actually was one of the guys who loaned us a heater. So to him we are equally grateful and will make sure the favor is returned.
Reactions: Harvest Fields
I don't understand how you are not managing to keep the house warm using electric heaters.
If they are the oil-filled rads, that makes sense, because a lot of them are electrically rated at 3kW but then cannot actually give 3kW as heat to the room so they cycle on and off, so perhaps they give out 1.5kW only, or less.
A kW or two per room is usually sufficient, and most electric heaters will give out at least 1 kW, if set to full. Expensive way of heating a house, but it should work. I'm obviously missing something.
if its rated at 3kw why should it not do that??
guess i will never be a plumber
Happy to take money when it is heading in their direction. Kick you off contract when they decide you are no longer likely to be profitable, with an older boiler they might actually have to fix after 10 years of "servicing". Really if they have been "servicing" the appliance from new there should be no sludge in the system as they should have been keeping inhibitor levels etc right in the water ways of the heating system.
Firstly it is incredibly unlikely that the attending engineer had a vokera heat exchanger on the van unless it was ordered specifically for that job. It is not a general van stocked item.
So I suspect the job may have been booked in and the attending engineer wasn't fancying the work involved so used the old powerflush get out.
Have you had any other parts replaced that have failed due to reported evidence of sludge?
If not then they have to honour the first fault as stated in their terms and conditions. It is only once it has been proven to have been caused by water quality issues that they can then refuse claims on future sludge related failures unless a powerflush is performed.
Also if you are going to go ahead and get the boiler replaced then ensure your installer is thoroughly powerflushing the system as part of the works, otherwise you may find yourself in a similar scenario with regards to voided boiler warranty due to not being flushed sufficiently before installation.
Lee
Lee
This is how BG stacks up. The service call at £13 per month does not return a profit for British Gas. Every call out costs £65.00 so a two hit job pushes them into a loss on that property.
Thats why Centrica are trying to sell it all off but no one wants it because of the pension mountain. So all their service and radical boys are under massive pressure
to sell up in any way shape or form. It might be a CO monitor, a magnaclean or in your case a new heating system...there is residual profit in there. Mind you because they are in a hole the new boiler and system installs are great value if you look at the whole package, interest free and loads of cover inc. but make sure you nail the salesman down to the floor and make him return at least twice as he will give you a good deal second time...out of his % from the 1st time..
I would always use a local outfit but in this no neighbours modern world no one talks to their neighbours...I know all mine. they are lovely .centralheatking
I think Which? (The Consumers' Association) brought this to my attention. I can confirm I had a DeLonghi 3kW rated oil filled rad. The heating element was indeed 3kW and when switched on and running, it would draw 3kW through the electricity meter. However, once the oil was warm, the radiator was unable to transfer the heat out of the oil as fast as the heating element was heating the oil. So at this point a safety temperature heat limit thermostat stopped it heating any more until it cooled down a little (all exactly as described in the Which report). In practice, in normal usage, the 3kW rated oil-filled rad was converting electricity into heat at around 2kWh per hour if I remember correctly, not 3kWh per hour as would be expected.
Since a water-filled radiator in use in a central heating system is rated for conditions that are not anywhere near that far out from normal usage conditions, a 2kW central heating radiator will chuck out (roughly) the 2kW you would expect.
As such I would agree with you. If it's rated at 3kW it should do that! And, in practice, a fan heater, halogen, or even the very cheap type of convector heater where you can see the wires generally does do that, so I think it's very misleading.
I use several 2 kw flood lights in my workshop, 100% efficient heat & light
centralheatking
  • Agree
Reactions: Ric2013
