Boiler leak suddenly overnight
View the thread, titled "Boiler leak suddenly overnight" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Good morning, My old RHINO boiler has developed a small pin ***** leak at this plastic joint, its a threaded cap with some wire coming out top, any one know best cure ? Thanks
As Shaun says it's a common problem with flow switches. This needs to be replaced sooner rather than later. Ive known leaking flow switches to take out PCB's and damage burner components
many thanks gents will try to find one, quite old boiler Rhino
Just google your boiler make and model flow switch, you should be able to find one. Alternatively you might be able to adapt with a different make, a flow switch is just a paddle inside that connects a live and switch live
Reply to the thread, titled "Boiler leak suddenly overnight" which is posted in Boiler Advice Forum on Plumbers Forums.
eemeg,
WHPES,
