many thanks gents will try to find one, quite old boiler RhinoAs Shaun says it's a common problem with flow switches. This needs to be replaced sooner rather than later. Ive known leaking flow switches to take out PCB's and damage burner components
many thanks i will have a lookJust google your boiler make and model flow switch, you should be able to find one. Alternatively you might be able to adapt with a different make, a flow switch is just a paddle inside that connects a live and switch live
cheers ,think i have one now, thanks for your helpSika flow switch. On the shelf.
Reply to the thread, titled "Boiler leak suddenly overnight" which is posted in Boiler Advice Forum on Plumbers Forums.
