Jan 10, 2021
36
10
Uk
DIY or Homeowner
I have a boss adapter to connect to my basin waste to soil branch but the I am trying to work out what connector I need on the boss itself to connect up my 32mm solvent weld waste pipes.
I currently have a solvent weld adapter in the first picture below and my ABS 32mm waste fits in there to solvent weld. The problem is the adapter is PVC and read you cant solvent weld ABS to PVC. I then found the following adapter which would work as it doesn't require solvent welding the waste onto it however how would I then convert to a solvent weld pipework further up - do I need a coupler of some sort? I don't want to use push fit pipework as it will be behind tiles so working out a way of changing from push fit (at the boss connector) to solvent weld later on...
Adapter For Boss
  • Informative
Reactions: Ric2013
Does that mean you have solvent welded ABS to PVC at some point along the run (unless you run all your pipework in M-PVC)?
tbh it’s a possibility as I don’t look at what city’s give me in regards to boss and adapter
Then it seems to be that while solvent welding ABS to PVC may be 'wrong', it seems to work 🙂
I went to city and they gave me the boss and adapter but went back today to get the push fit equivalent adapter to see what that is like. I had a go on some scrap 4 inch on drilling the hole for the boss adapter as I had a spare 57mm hole cutter in the garage but I think may actually be a 55mm hole required for the hole itself. I have a picture of the hole below not sure if I am going to benefit much by drilling a smaller hole as I would hope the solvent cement (gap filler is on order today GFC100) would do the job....
Its interesting to know what you do in the trade regarding the PVC to ABS solvent weld and seems like many do it that way with no issues. If there were big issues with it I would imagine it would be strictly not advised as a disclaimer on instructions for items. Now for me to decide weather I use the push fit one in the picture below or the solvent adapter I have.
I haven't bothered deburring this hole I cut as it was just to see the fitment.
If the op tries a mech boss next time - no glue needed !
https://www.NoLinkingToThis/p/mcalp...Np9X0DD44RjMyiKDktBoCTskQAvD_BwE&gclsrc=aw.ds
Reactions: danielson
To be honest by the time I faff around finding a smaller hole saw I may as well buy the McAlpine one and send the solvent cement back.
I really like the idea of being able to compress both either ABS or PVC pipe to the connector on the boss so you can then solder further along he connection.
Reactions: WC1
Looking back on page 1 I can see that you already considered it. Mech boss is genuinely very good kit.
