Brand New To Forum Hoping For Help
View the thread, titled "Brand New To Forum Hoping For Help" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Thanks Best. I've popped it in my basket for when it comes to changing valves.
I would point out though that it only does 15mm and up, not under, so no 10mm etc.
It certainly seems better to have one of those than a purely dedicated width as you say.
Im also looking to move some pipes around. Could you suggest a cheap but good blow torch system. I see you can get heads that screw on to cans but the heads vary widely in price.
Im hoping for something around £25?
P.s where in the uk are you based roughly?
Have you soldered before
Hey Riley.
Yes I have I'm into Arduino's and robotics. Im also aware of how to prepare a copper pipe and how to join them using solder and osmoses. If i;ve got the correct term, i.e allowing the solder to be sucked up into the joint by itself.
I'd probably do a test piece first and put it under some sort of pressure to check for leaks in my method but other than that I don't see it being as much of a problem as say not flooding the house (i.e correctly draining the system or leaving a bleed valve open on refiling).
I am in the Best place. 🙂
Northern Ireland.
To answer your question of what would be a good cheap blow torch, - truth is you probably need to pay a bit more to get a "good" torch.
The Rothenberger Surefire 2 is what most plumbers recommend. It is reliable and produces a small powerful flame and doesn't flare up. Probably cost you about £50 for the bare torch. Or you can buy it in a Rothenberger choice of plumbing tool kits for little more, making that a better option in my opinion.
Reply to the thread, titled "Brand New To Forum Hoping For Help" which is posted in UK Plumbers Forums on Plumbers Forums.
The Carlton Dance,
Best,
