Guest viewing limit reached
Britony Combi SE 100 boiler fault
View the thread, titled "Britony Combi SE 100 boiler fault" which is posted in Boiler Advice Forum on UK Plumbers Forums.
As you seem to have movement thru the plate heat exchanger then as a guess it's either because the diverter valve assem is defective(less likely as you have replaced it) or as water will take the path of least resistance it's easier to force it's way round the diverter valve than do a circuit of your heating system, pointing at your system design/defects(as posted by others). While you have heat bypassing the heating circuit the boiler is going to achieve temperature before it would do under normal operation and the heat ends up pulsing out.
Thanks everyone. I'm going back to the house next wk (23 Aug) and I'll do the things you've kindly advised. I'll let you know the outcome. I'm really grateful to you. Ian
Reply to the thread, titled "Britony Combi SE 100 boiler fault" which is posted in Boiler Advice Forum on Plumbers Forums.
Gregorian,
Gregorian,
