Calculating pipe centres
View the thread, titled "Calculating pipe centres" which is posted in Water Underfloor Heating Advice on UK Plumbers Forums.
Similar to radiator dT's, is there a way to mathematically calculate the UFH pipe centres required to satisfy a given room's heat demands?
150mm-250mm centres are banded about online, with no real explanation, obviously smaller centres allow for lower water temps, but there must be a more scientific way on deciding the centres for a given scenario?
Tbh you can work it out eg via cibse ufh guide or via a paid software but I normally go 100mm centres and work out the flow rate etc eg 1kw needs 2.04 lpm
Reply to the thread, titled "Calculating pipe centres" which is posted in Water Underfloor Heating Advice on Plumbers Forums.
eimaj123,
ShaunCorbs,
