Can I add a seperate header tank to a fortic cylinder?
View the thread, titled "Can I add a seperate header tank to a fortic cylinder?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
G
Geddoffme
Hi I just bought a house with a combination hot water cylinder & cant replace the heating system yet as we have walls to knock down etc where the new radiators would be & the new layout will require different sizes.
My GF needs a more powerful shower its a trickle atm. I ordered a pumped power shower then discovered you need a large cold water tank, the discovered its a combination cylinder.
We only need it short term. Could I fit a 50gallon tank above the combination cylinder and just use the bottom half of the cylinder & conect all the pipes between the two to the new header tank? It isn’t pre-insulated btw.
Yes it’s the vent with a standard cylinder this is brought upto the cold tank
With your combined cylinder it just dumps back into the little tank
Reply to the thread, titled "Can I add a seperate header tank to a fortic cylinder?" which is posted in UK Plumbers Forums on Plumbers Forums.
Geddoffme,
ShaunCorbs,
