Hi there,
we are having issues with Mitsubishi ASHP Pre Plumbed cylinder.
we have 2 zones. UFH and radiators on the first floor. Feeds come off the low loss header at the tank. Both pumped.
UFH works fine. It’s the rads that struggle. We always seem to get loads of heat to the rad valves but it really struggles to flow properly around the radiators. SO FRUSTRATING
System balancing has been done over and over. Pipe sizing is all really good. Pump speeds are equal, bypass are only cracked open.
the only thing that has changed in the most recent installs are the levels of anti freeze. Systems used to be protected to 10% -5c and are now 10% -20c
I’m not sure if the extra anti freeze is causing problems with the thermostatic radiator valves??? I may be clutching at straws but I’m not sure what to try next. The anti freeze was pumped straight into the UFH manifold. Would it have been better to mix with water first and check with refractometer then pump in?? Is the fluid thick at the valves if not mixed correctly???
Any ideas would be great
