b0ng0
Hi all,
We had a new replacement Grundfos pump (Grundfos 15-90N) installed late last year. Shortly after, the TRVs on all the rads (although only one at a time) started making a really loud banging/whining/clunking sound when starting to reach temperature.
The valves are Myson One-Way TRVs (about 15-20 years old at a guess). I have tried feeling which pipe gets hot first when turning on the rads and it appears to be the side with the lockshield that gets hot first - which would indicate to me that the flow is going in the wrong direction relative to the TRV position.
I'm a bit confused, as the new pump was an exact replacement of the old one and it's installed horizontally so surely by replacing the pump the water direction shouldn't have changed.
Also worth noting, that there was never any issue before the pump was replaced. Could the new pump have pulled some sludge around the system and its accumulated around the valves?? I'm totally at a loss as to how to proceed with fixing this without doing anything unnecessary.
