Thanks Shaun but I did not get the last word meaning? iid?Should be after the llh
I hope there’s additional expansion tank / tanks ?
Sounds like you need to separate the system. Also is the old boiler a non condenser @ShaunCorbs and the rads possibly ∆T 60?
No, the old boiler was a 20 year old Ideal Concord CX40 floor standing unvented.Sounds like you need to separate the system. Also is the old boiler a non condenser @ShaunCorbs and the rads possibly ∆T 60?
Yep
Low loss header
Then if the old boiler was running at ∆T 11°c the pump would of been capable of the higher flow rate and pressure required to overcome index circuit.
Sounds like this needs a low loss header and suitably sized secondary pump. The secondary side pipework will be ok in size but the new boiler internal pump isn't capable.
Alarming really as the installer really should have considered this 🤔
I agree. The boiler developed a leak from the heat exchanger seal 9 weeks in and charged 200 quid to do a 35Then if the old boiler was running at ∆T 11°c the pump would of been capable of the higher flow rate and pressure required to overcome index circuit.
minute job under guarantee. Now they do not want to know.
This customer is prepared to spend money in excess of what was paid for what should have been paid underThat would of been a warranty job and the manufacturer liable for payment, not you!
Unfortunately to rectify this is going to cost more and the situation clearly demonstrates the installer doesn't understand the principles.
yes hat makes sense but I have to get the water around the system in the first place.I think between us we have arrived at the problem. My concern now though is as I mentioned above are the existing rads at ∆T 60°c, if so the flow temperature will need to be around 90°c to give a rad MWT temperature of 80°c and full out put.
