You are magic and clever so thank you.Yes I agree completely. However I suggest separation, pumps in series is not always going to work.
That is also my logic and I thank you for your help. If the boiler produces hot water and the circulatory systemAfter the external heating plate heat exchanger which will need to be added
I have a qualified engineer arriving tomorrow afternoon. Thank you for your input! John.
Close enough
As you said close enough mate but I must add if the secondary side is staying open vented then pump in that image is not situated ideally. One would need it to be V,C,P on the flow out on secondary side.
Not sure but will check out. There appears to be a vast misunderstanding what the roles are between plumbers, heating engineers,Do they do commercial heating systems ?
If it’s a combi it’s sealed or they’ve linked the pressure switch out as navs can’t be run ov
central heating specialists.
Yes, life is full of givers and takers. I find it easier to be a giver as I sleep soundly.We do this because we are passionate about our industry, unfortunately for your friend he employed the services of someone who quite frankly doesn't know the basics and as Shaun mentioned before that's damaging.
Well done for sorting out my problem.
£2400 supply and fit but did not supply commission document or make the system work. They said that the lackWe've arrived at the problem and can advise on the possible solutions but ultimately it's down to you to find a suitable engineer. Unfortunately knowledge and experience comes at a price, something you and your friend have now discovered.
Can I ask, you said your friend was charged just over 2k, was that supply and fit?
