CH off but rads are heating when hot water tap turned on
View the thread, titled "CH off but rads are heating when hot water tap turned on" which is posted in Bathroom Advice on UK Plumbers Forums.
My CH is off. Rads are stone cold then I turn on hot water tap and the rads start heating
The water takes ages to heat through the tap yet the boiler is just the other side of the wall 40" further along
This is a new boiler just installed this week Ideal Logic + 30w
Also 3 rads at other end of house with no heat at all but did heat before new boiler fitted
Fed up OAP !
They are phoning tomorrow.
I've had water leaking through kitchen ceiling and light fittings etc................ and they say all the rads work only not all together. They said if all the rads one one side are turned off it pushes hot through to the other side..I don't want to have to choose which side of the house to heat as it all heated before they started!
They were quick enough taking the money...don't know if Santander credit card will help out
I paid £3325 and that was supposed to include a power flush and the magna thing (which I got) but I then found out they didn't do a flush but put Ferex? in system
I am in Dundee and they are miles away in Glasgow
Hope this helps some are a wee bit fuzzy
White flex on left pipe under boiler.
Should be clipped to wall or In trunking. I can't open pics properly I'm afraid.
I would expect an installer to fully commission a system once it's complete. That is to ensure that the boiler and everything else works properly.
They should balance the system as part of that.
In your case it sounds like they did the job as quick as poss and ran away !
They were there for over10 hours on the day of instalation and then another 3 hours 2 days later to try and sort the leaks but still couldn't get all the rads to function together they said they might have to come back and take all the rads off ad hose them outside but to expect a real mess of black sludge on carpets etc
Very untidy installation,cables everywhere and pipeworks a bit of a mess,thats also not a magnaclean filter,its a cheap copy ,any photos of the flue off the top of the boiler to where it exits outside?
it goes into the loft and comes out of the roof..I will take photos tomorrow when it's light and try to find you again on here..I hope I can as its just good to be able to speak to someone about all this , I feel very alone and vulnerable, thank you for taking the time
Easy to find me or any other admins,look at site leaders at the bottom of the main page,we try our best to help with queries though you probably won't get a reply until the evening,most of us are active gas engineers during the day
Reply to the thread, titled "CH off but rads are heating when hot water tap turned on" which is posted in Bathroom Advice on Plumbers Forums.
jenny105,
paulalou,
