Changing push fit boss to solvent weld
View the thread, titled "Changing push fit boss to solvent weld" which is posted in Bathroom Advice on UK Plumbers Forums.
I'm currently DIYing my bathroom and have a soil stack with 3 waste pipes bossed into it (bath, basin and bidet) - all waste is currently push fit under the floors.
Before I tile the floor, I'm going to replace all the push fit waste with solvent weld - it's not leaking but seems prudent as it isn't well supported so will need attention anyway. I'm getting rid of the bidet so will purchase a push fit blanking plug to blank that boss off.
Question is - how would I easily change the remaining 2 push fit bosses to solvent weld? From what I've googled, it's likely the bosses are solvent welded onto the soil pipe so not sure how to remove without damage. I cant "just have a go" without a plan as the soil pipe has the other toilet connected to it further up so don't want to bugger it up! I appreciate I can connect the new solvent weld waste to the old push-fit via a compression fitting, but that seems like an extra joint for no reason?
Thanks.
Reply to the thread, titled "Changing push fit boss to solvent weld" which is posted in Bathroom Advice on Plumbers Forums.
muppetman74,
muppetman74,
