Charles wet and dry vac
View the thread, titled "Charles wet and dry vac" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Scott_D
Subscribed
Anyone have any experience of the Charles wet and dry vac?
Trade-point are selling them pretty cheap £60+vat
Charles is a good vac not the cheapest only down side I find is the volumn is not the biggest regards Turnpin:8:
Not a bad price for the Charles!!
I've got a Karcher. I know some on here reckon they're not very good but as already said it was cheap so just replace when it breaks down. It hasn't got a huge capacity but then I mainly use it for cistern changes & the odd little bits. Don't use it for dry vac, got an old dyson for that.
Amazing price that! I am going to order one straight away 🙂
i had a cheap one once & it sprayed water up the wall! I'm guessing a Charles won't do the same!!
If your decommissioning get earlex or one with big storage but Charles is high quality. U don't need a lot of power in a wet vac though. 1200w ample .
Looks heavy to lug around. I have the Lidl one which is exactly the same as the Wickes one but with a slightly different handle. It is very light when empty, and i've sucked up thousands of gallons of pure horror with it. The filter is so blocked with human hair, magnetite and poo lumps that I almost retch every time I have to empty it. But it still works perfectly 🙂
Think wicks one is the earlex just re baged! We all got one for the brown incidents !
My Charles arrived today! £57.50 + vat from trade point! Great price... It's 160 from Screwfix!!!
I would like to know your thoughts.
Im planning on getting one next time im in B&Q
It seems a very well built bit of kit! Sucked up a bucket of water in no time with no mess or drips!
At that price I would get one sooner rather than later, doubt they will hang about!
Now to make room in the van!
It's 15 litres dry or 9 litres wet... Not the biggest but should be okay for plumbing I hope!
Wow, 9 litres is awesome. I was doing a powerflush the other day and as the f&e was full of gunk I didn't want to risk draining down. So put 1/2 cap on tank connector and sunked out. But vac filled up by half way. Didn't enjoy having to carry it up and down the loft
Much better than not having one though....
Sypon in to loo from headder, use Hoover to do sucking. When syphon stops . Shove 1m of hose into Hoover shove glove inside Hoover pipe so most of power transferred into hose pipe , stand Hoover in bathroom switch on and use hose in attic like a long Hoover pipe. Doesn't work well with hot water and reign drain down hoses. "Big red"
I have the triton very cheap and really good bit of kit thinking of putting drain of on so can connect hose
Did you get the standard trade point reply -
Tp: Sorry it's not available
Me: can you order it?
Tp: no
Eventually someone works out how to do it.
Reply to the thread, titled "Charles wet and dry vac" which is posted in UK Plumbers Forums on Plumbers Forums.
Scott_D,
gassafe,
