phoenixx235
One of my radiators doesn't warm up. Checked the pin on the thermostat, flushed the radiator in case of sludge. I bled all of my radiators and turned them off, apart from the one in question.
The inlet pipe gets very slightly warm, the outlet pipe is very cold. When I disconnected the plastic outlet pipe, water gushed from the pipe (a large bowl's worth). The water was filled with lots of black particles. When I disconnected the plastic inlet pipe, there was a constant dripping of water from the pipe. The water that dripped from inlet pipe was noticeably clearer than from the outlet. This was with the radiators valves set to off, so no water came out from the radiator. I used a small flexible wire to to and clear any blockage in both pipes, but nothing was there within the 10" I could reach.
I have emptied and flushed the radiator, when I reconnect I can hear it refilling, so I know at least the inlet is clear. When I drained the radiator, I disconnected both pipes. I opened the valve on left (outlet), no water came out from radiator at all. I opened the right valve (inlet), the water came out.
Could the problem be due to a kinked pipe on the outlet (or a clogged outlet pipe) or a defective valve on the outlet?
