- May 23, 2015
- 35,144
- 1
- 14,996
- 113
- Member Type
- Heating Engineer (Has GSR)
We will have to have a new gas meter installed anyway if the job goes ahead as the current one will be undersized. Can you shed some light on typical meter operating pressures? I understand that standard domestic is 21 mbar, the current meter on site just says <75mbar. What's likely to be the standard operating pressure of that meter? Can we go to higher pressures? and does that bring in more complications? I would guess the usual way is to keep pressures past the meter low and to increase pipe diameter?
Cheers.
You would have to speak to the network provider see what they can supply
If you go with steel tube get a commercial engy to work out what he requires, and get him to install it with a coded welder
