commercial pictures ?
View the thread, titled "commercial pictures ?" which is posted in Industrial Plumbing Advice Forum on UK Plumbers Forums.
Yeah and it was big, but not that big! Have you got any incentives over in Ireland, or is just the fuel savings compared to oil enough?
Once they release the RHI for domestic I think we will see some growth in the renewables market over here, for a minute i've gone back to gas work as the uncertainty surroundings the whole thing and the feed in tariff fiasco for solar P.V has made the public very wary of the whole thing by the sounds of it.
Wow, generous over there, think its £850 over here, can't remember now, I must have learnt something new and its pushed this out of my memory bank :teeth_smile:
i bet that lightens the blow a bit as its not cheap is it
Air Source Heat Pumps - £1,700
Biomass boilers - £2,500
Ground Source or Water Source Heat Pumps - £3,500
Solar Thermal - £320
sorry i will get some up i do more toilets and catering sides so sadly no big boilers. why is it that every resturant wants to be open before xmas. the deadlines and time for the sites gets shorter and shorter.
Went into a plant room the other week, normally just touch the domestic side but was asked to increase pump speed on the pumps.
Flues are shagged hence the at risks for each boiler!
by the way, I'm not commercial.
Scan10121.jpgScan10013.jpgNot sure if I should be posting these here cos this is somebody's house !! A good few years old now, but still one of the smallest to house 150kW's & the only fully tiled boiler room I've ever done.
Ar just remembered it was my first U/F as well, no mixing at the manifold on this one, it was a variable temp circuit in the middle of that lot.
So can I stay Plea.....se ?
Can't even say it was 35mm + gas supply cos that's the 1/2" line coming in bottom L/H side.
Sure is. One of four six bedroom houses owned by one of the wives of a Middle East(can't say which country) king.
This is what I have been doing for the last 5 dayscovenham 050.jpgcovenham 049.jpgcovenham 048.jpgcovenham 051.jpgcovenham 052.jpg 300mm ductile cement lined pipework and 300/ 350mm stainless steel pipe.
Installing UV reactors for the water co.
Flushing and testing for a few days now.
Nice when you get to go back to see your work and the lagging is complete and floor painted.
Reply to the thread, titled "commercial pictures ?" which is posted in Industrial Plumbing Advice Forum on Plumbers Forums.
on31ll,
Sparkgap,
