commercial pictures ?
View the thread, titled "commercial pictures ?" which is posted in Industrial Plumbing Advice Forum on UK Plumbers Forums.
I've got two froelings I look after. Absolute poo.
I would've gone for a Hoval STU.
The boiler itself was fine, weve done a few 200 kw frolings and they are ok, bit too fussy, but work ok. the problem with this one was the heatloads totalled 140kw and the boiler was only a 90kw, the buffers were 2x 1600ltrs which is a bit on the short side, and because of the way they designed and controlled it, the boiler was always trying to provide heat for the system running 24 hrs a day even in the summer and the buffers sat cold.
just started on a new install, replace a binder biomass boiler for a froling one and completely repipe plantroom, install buffer tank in seperate building. DSCF6778.jpg20150206_161607.jpg20150207_142519.jpg20150207_160027.jpg20150207_160038.jpg20150203_130830.jpg
Hi missplumb,
I'm surprised you are still working in copper on these scale installs, I would have expected LCS given the cost! Any particular reason why?
We are on a baby Froling next week, all 15kw of it along with a colossal 500 litre buffer!
We've priced copper and lcs on a few jobs and there was only £500 in it. Then there is different cutter blades etc, and we get a decent price for whatever copper is left at the end of the job from the scrap man
the boiler we are doing is a tx250 with a 6000ltr buffer.
A flow header and a return header, they are linked and pre heated by a CHP unit
The m+f Iron bends? A mapress adapter and bend and quite bulky so used them to keep it close
fair enough just looks out of place esp the t
Reply to the thread, titled "commercial pictures ?" which is posted in Industrial Plumbing Advice Forum on Plumbers Forums.
on31ll,
Sparkgap,
