commercial pictures ?
View the thread, titled "commercial pictures ?" which is posted in Industrial Plumbing Advice Forum on UK Plumbers Forums.
Looks good miss
What you do with the old stuff
Not good what a waste
Can't you recycle them
Make a bit extra then
Froling isn't cheap stuff
I agree with tamz you work is looking excellent
tbh, it wasnt part of our contract to remove the old gear from site and we wouldnt be happy fitting a new boiler and connecting it to existing buffers etc, if they failed then it wouldnt look good for us even though it wasnt our fault.
it was fitted by Econergy (british Gas). it was done about 2008 so before the rhi was available. everything was undersized, boiler, pumps, expansion vessels .
I've got two froelings I look after. Absolute poo.
I would've gone for a Hoval STU.
The boiler itself was fine, weve done a few 200 kw frolings and they are ok, bit too fussy, but work ok. the problem with this one was the heatloads totalled 140kw and the boiler was only a 90kw, the buffers were 2x 1600ltrs which is a bit on the short side, and because of the way they designed and controlled it, the boiler was always trying to provide heat for the system running 24 hrs a day even in the summer and the buffers sat cold.
just started on a new install, replace a binder biomass boiler for a froling one and completely repipe plantroom, install buffer tank in seperate building.DSCF6778.jpg20150206_161607.jpg20150207_142519.jpg20150207_160027.jpg20150207_160038.jpg20150203_130830.jpg
Hi missplumb,
I'm surprised you are still working in copper on these scale installs, I would have expected LCS given the cost! Any particular reason why?
We are on a baby Froling next week, all 15kw of it along with a colossal 500 litre buffer!
We've priced copper and lcs on a few jobs and there was only £500 in it. Then there is different cutter blades etc, and we get a decent price for whatever copper is left at the end of the job from the scrap man
the boiler we are doing is a tx250 with a 6000ltr buffer.
Reply to the thread, titled "commercial pictures ?" which is posted in Industrial Plumbing Advice Forum on Plumbers Forums.
on31ll,
Sparkgap,
