Yesterday afternoon about 6:45pm boiler switched off electrically.Yes, about 0.5litres/0.05bar from that 35 litre EV. so looks like a fairly serious leak, its a pity if it turns out to be a stupid drain valve but must be fixed so time to call in the professionals I think.
Jug filled up around 10:30pm.
So this morning (boiler cover on by the way) the pipes shuddered when the valves to the boiler were opened and pressure down by 0.1.
Repressurised to 1.5 and the water started coming out of the condensate line... dripping.
Had a minor brainwave and tested the ph of the “condensate” and found it to be little less than 8 so definitely not acidic as condensate should be. [stupidly never tested the ph of the condensate when the boiler was on so don’t have an accurate reference but am sure it needs to be 6 or less].
there is one more thing I could do and that’s add a dye into the central heating but I’m sure that would blow my warranty. But once out of warranty if this happened again I might go that route. Oddly enough doesn’t seem to be CH dye on the market - other than drain dye.
Anyway thanks all. On the phone to Worcester.
