3 bed terrace
Hi, new non-plumber here in need of advice from some experts![I have a 3 bed terrace with no central heating.
I have employed a friend of a friend plumber to install a new combi boiler and rads. He's worked on it for a couple of days but I'm not very impressed with the work, am I in the right?
He said to use plastic speed fit pipes to avoid taking up all the floor boards. I did a bit of research and am ok with this.
He has started doing all the plumbing in 15mm rather than 22mm as comes off the boiler. I was under the impression the 'loop' should be in 22mm with 15 mm going off the the rads?
Also, Where he has run the pipes in the ground floor in the void under the floorboards he has not clipped any of them, them are all just hanging (it's big enough to crawl under) surely this isn't right?
