Diagnosing banging motor valve
View the thread, titled "Diagnosing banging motor valve" which is posted in Oil and Solid Fuel Forum on UK Plumbers Forums.
I have a three-zone 2016 house with gas heating. When the downstairs heating switches off, it bangs extremely loudly. I have tried adding clips and it only helps to a point, I would have to take down plasterboard to get at the noisest part. The valve appears to be the correct direction. I have a bypass, which seems to be working. I think the bypass pipe is about 15mm. I don't have any TRVs anywhere in the house. Do you think I might need a new valve or perhaps something like an automatic by pass? Thanks a lot.
If it’s previously worked fine, then something has failed, ergo you shouldn’t need to change piping etc.
Pressure looks a little low, had any issues with losing pressure, needing to top up more regularly?
Expansion vessel possibly lost charge/faulty?
You say the zone valve appears to be fitted the correct way, any proof of this?
Good point. I really don't understand the system so maybe I got that wrong. Here is a picture of the arrow. Is that the only factor to ascertain its direction. Do I need to open it?
I had a similar issue recently after customer had new boiler with bigger pump fitted , I added an auto bypass before zone valve and haven't heard anything back - so guess it's ok
Valve seems in the correct orientation
Interesting. Is there a theoretical reason why an automatic bypass is needed and that gate valve is not enough?
The ABV method is more energy-efficient than the always-open gate valve. This is because the gate valve (permanent) bypass raises the return temperature, which adversely affects heat recovery by condensing boilers.
Thanks. I will investigate further and ask a plumber to help with this.
Hi, I figured out that there is a radiator in the upstairs zone (none noisy zone) with no TRV, which i guess acts as a by pass. I guess I will end up getting an ABV anyway, and just have two.
It seems the bypass pipe with the current gate valve is just 15mm so I called the boiler company (Ideal) to ask is this ok or should it be 22mm. Id replace it to 22mm if needed when. But ideal refuse to advise as I am not gas registered.
Reply to the thread, titled "Diagnosing banging motor valve" which is posted in Oil and Solid Fuel Forum on Plumbers Forums.
red_rover,
ShaunCorbs,
