W plan EVEN 🙂
We do not understand this statement please explain what you mean?
My current setup seems reasonably well balanced, no hot or cold spots in the house. All the rads have thermostatically controlled regulators. What do I need to know about balancing that can help me in this?
I set the boiler temp to 70C. Before it gets much over 40C, the main house thermostat stops calling for heat. I guess my house has more radiator capacity than it needs, but I guess low return temps will be good when I eventually have to convert to a condensing boiler.
Because the zone valve to the cylinder will only be open when the cylinder is below set point eg 55 degrees. When the flow temp is greater than 55, heat will only be transferred into the cooler medium, ie the water in the tank.
The laws of physics prevent it doing any different.
When the cylinder is satisfied eg > 55 degrees, the zone valve will close, preventing circulation, although this is still preventing it from being heated further as opposed to any heat being removed.
If your boiler stat is 70 yet you can only get a flow temp up to 40, something is wrong.
You will be having work carried out that means your new heating system & controls will need to be compliant with Building Regulations AD Part L1b.
The C-plan system will not meet these & it will not be suitable when you have to install a new boiler.
W plan EVEN 🙂
Your primary and Heating circuits need to be balanced.
It's marginally possible, but much more likely to be a sign of an underlying fault on the system.
siricosm, you've been given good solid advise by some of the most experienced heating engineers in the Uk and yet you are still questioning their advice with spurious assumptions on your part.
I am not here for advice, I am here for understanding. I just want to know what my options are, before I decide how to proceed. As I mentioned in a previous post, I am not installing anything in my house until I fully understand how it works, and what alternatives are available. Your post seems to be suggesting I should just "leave it to the professionals". Unfortunately, I have had too many experiences with "professionals". If you can actually answer the original question in my first post, then please do so.
Reply to the thread, titled "Different boiler temps required for hot water vs radiators." which is posted in Boiler Advice Forum on Plumbers Forums.
