SamPDP
Hello All
I run a small property maintenance and development company, and one of our closest colleagues is an excellent plumber with whom we do many boiler changes and bathroom installations.
Recently our plumber has been in dispute with a customer of her own, who is attempting to make a claim against her insurance on the grounds that, two years ago, she fitted a bath tap for them and forgot to put a washer in, causing damage to their property. Now, they claim that the damage was caused over the course of the two years and that they only recently uncovered the damage, but it is my understanding that if you fail to put a washer in a tap, water kind of sprays out everywhere. I removed the washer from my bath tap and turned it on, and found water going everywhere. So I struggle to think that the customer took two years to notice this! Surely water would have flooded out under the bath panel at the very least?
The customer had an inspection carried out by a builder, who confirmed the missing washer (naturally my plumber was not invited to the inspection). My plumber's insurers have investigated and refused to pay out, saying that they basically do not believe the customer. The customer's story has now changed, saying that there was a washer but that is was fitted "incorrectly" - I'm not sure that you can even fit a washer incorrectly, there's not many options for failure, apart from the fact that my plumber has been doing this for over 10 years without any other problems at all.
Any comments/views? It looks like the customer is going to take my plumber to court and naturally we will be supporting her, so anything helpful at this stage from the forum community will be appreciated. Please ask me any questions you like.
Best wishes
Sam
It does certainly sound like they are trying it on. The fact that your plumbers insurers have investigated and are refusing to pay says it all to me. I would personally welcome the day in court and enjoy my victory over a chancer.
Are they talking about the washer in the tap (which is what we automatically think of) or the washer in the tap-connector.
This story makes more sense if there was a minor problem with the tap connector washer, which could theoretically have leaked quietly away for 2 years, depending where the water was going.
Probably a failed fibre washer that failed quite recently to cause the damage and cust is clutching at straws to blame somebody. Crap happens and its not always somebodys fault.
I agree that's the most likely scenario. The fact that your plumber was not allowed to inspect the problem will also go against the claimant.
Reactions: 2 people
i have paid out on my insurance recently and it can be quite costly on your following year
does sound like a cust trying it on and i would tell them to take me to court
Hi Sam,
Just a query to clarify, when you refer to 'her' in you post.
Is your plumber a female?
Is the customer you refer to a female?
or are both females?
Not that this is an issue, but I cannot decipher the difference between the customer and your plumber in your OP.
You state your customer is going to take the plumber to court and you will be supporting 'her'.
Who is 'her' that you are going to be supporting?
Either way, the insurance company has fobbed it off, so let the customer battle it out with the plumbers insurance company and the builder that declared the fault being the plumbers.
The insurance company has more time and money to spend on the court case than you and your plumber do, so let them sort it out.
The more you and your plumber get involved from here on in will add to your detriment and to your financial well being.
As hard as the situation is, let the situation resolve itself without your involement.
Someone is going to get screwed, let the courts who that is!.
Don't lose sleep over the situation and let the insurance company's sort out the liabilities.
What's the worst you or your plumber will be up for - your excess.
Leave it at that.
PS: been there and done that. This is the best and easiest solution.
Oz Plumber
good point by oz plumbs
why did they get a builder to inspect??
how are they qualified in plumbing?
surely you would get a plumber to inspect
Where's the proof that it has been leaking for 2 years, and who guarantees their work for 2 years ?
This sounds like a load of b******t. The fact that the story's changed from no washer, to badly fitted washer won't have done the claim any favours. It should be treated as wear and tear, and the owner should claim for any repairs from their house building/contents insurance like any normal rational person would. It could be that the owner has a history of frivolous insurance claims which might explain the refusal to pay out by the insurance company.
When it gets thrown out of court, make sure your plumber puts in a claim for time/expenses associated with this case against the house owner.
its one of those unfortunate things that comes with owning a property things fail
changing story from no washer to badly fitted washer sounds like someone grasping at straws to avoid paying
also its possible the washer was defective from new which then involves the supplier and the the manufacturer
i cant imagine a scenario where a dripping tap con could run for 2 years and do much damage without it being noticable it therefore must be ground floor and what damage could it have done there?
I had new brakes fitted to my car 2 years ago, now they dont work, ive checked them and the pads hardly have any material on them. Its the garages fault, they fitted pads which were faulty............. ive only used my car every day and done 40,000 miles.
oh and my mate has a t shirt that reads im with stupid 🙂
Reactions: 4 people
Seen a few leaks left by plumbers that have been going for a few years sometimes & they didn't show at all until ceiling cracked. So it does happen.
It could be the fibre washer on the tap fitting or I have seen a lot of taps that have no washer or sealant fitted between them & the sink or bath, resulting in any water from showering etc to drip for years.
A lot of baths have far too big diameter holes for bath taps & need to be careful fitting tap centred.
Sounds like this woman is a chancer though.
She's at it, changing her story and not letting the plumber be there on inspection = chancer.
That said, anything is possible but such is life. Customer/claimant won't win
The fact that she wasn't called or asked to attend is spurious enough already, fact they asked a builder round.............
If theyve changed their story with insurers aint no way insurance will pay out.
Hell will freeze over 1st...
It is possible that a damaged washer was fitted or a good washer was distorted during installation. Either way, a good plumber would have underaken a leak test overnight to check everthing was watertight before completing any finishes, so it seems unlikley unless the work was rushed.
So if you went and installed a set of taps you would install them then go back the next day to check for leaks?
If they have changed their story it will get thrown out of court (If it even gets there) and the fact that you were not asked back to repair leak will go against them.
Reactions: 4 people
