stevep
I have a heatline c24 condensing boiler diverter valve actuator/stepper motor is not moving.
The central heating and hot water work correctly if i operate the diverter valve manually.
Continuity of the 3 lead actuator/stepper motor power cable is ok.
Actuator/stepper motor has been replaced.
I suspect the main pcb is at fault and needs replacing.
Can anyone confirm this is the fault and that nothing else could be at fault.
Cheers
Buddy by the sound of it your 3 port motorised valve is broken, best thing to do is just replace the whole valve hopes this gives you some help.
