Does anyone use a Borescope to inspect flues in voids?
View the thread, titled "Does anyone use a Borescope to inspect flues in voids?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Back to co alarms,most are not suitable in bathrooms due to moisture,so all flues in boxing through bathroom,which there are many,have to have inspection hatched now or AR ?
Someone mentioned to me the other day,you can fit one in the room(s) next to bathroom,is this correct?
One of my customers has got a boxed flue without any hatches in a bathroom . I've install the bathroom for him. The flue has been boxed way before me. I haven't touched his boiler yet. I don't think he's gonna like AR. Oh dear!
It matters not a jot who inspects it, it'll still be AR. If an engineer is willing not to AR then they deserve to receive every punishment available
i totally agree with this, and its something a lot of guys have said as soon as we tell them about TB008 when they are in for re-assessment (it is shocking that they dont know about it by now, but that just shows their firm or their own (if SE ) procedure for keeping up to speed is way short of what it should be) but they are sharp enough to know that as soon as they start filling out the Warning Notice and sticking on the AR aticker then they wont get called back again next year, so something that is intended to increase safety could end up decreasing work to the guys who are doing a good job
What happens the following year when the boiler is due a service?? They wont risk ringing any company out as they are scared it will need turning off and isolating this year. Does this make the boiler and flue safer?? So not only has it been found to be at risk or ID it will now more than likeley not be inspected for many years to come.
there is something of a precedent with backboilers and ventilation the public understood, this year is meant to be letting the public no whats coming, i havent had anyone slap me on the back and thank me for the inconvienence but thats life
All we know is that it was safe at time of inspection, but now we have potentially serious holes in the flue boxing, maybe in kids rooms etc for the flue products to leak out from if the flue gets damaged in between services.
I can see the good point in being able to inspect whole of flue and joints, but I can also see the potential hazards.
If the flue is properly supported along it's length; is fully inspected and safe during service; how likely is it to be damaged between services? As a procaution I always advise on CO alarms; even more so when the appliance is in a bedroom.
I would also say the boxing in would be unlikely to have contained the POC's from a split flue anyway. How likely is it that the boxing is 100% air tight?
Back to co alarms,most are not suitable in bathrooms due to moisture,so all flues in boxing through bathroom,which there are many,have to be inspection hatched now or AR ?
The CO alarm must be in every room along the route of the flue. In an adjacent room does not comply with the risk assessment. Even if the flue was to pass through a void in a neighbors property, they too must be given a CO alarm.
regardless, that's not your job to worry about what they will do next year if you AR or ID the appliance this year. If you NCS it because you fear you will lose work (as it is coming across like this in your statement) then you will be ripped up for erse paper in court of law should anything happen.
better a cold house than a cold body, this is the message as gas engineers we should be getting across.
I am not saying it for my behalf, I am just saying that home owners will stop getting appliances serviced.
As I dont do servicing I dont give a monkeys about them not calling me back the following year, I stick to installs so the chances are I will only come across these situations if I am replacing the boiler anyway so it wont matter to me as I will be getting the extra work of moving the boiler or fitted inspection holes.
Reply to the thread, titled "Does anyone use a Borescope to inspect flues in voids?" which is posted in UK Plumbers Forums on Plumbers Forums.
rjshook,
kirkgas,
