Irish
896
367
63
Heathrow
Evening all my friend has a flat he rents out with a boiler which has a vertical flue which goes straight through through the ceiling and flat roof, the bottom of the 6x2 roof joists is the ceiling, the gse from estate agents said it needs an inspection hatch as its going through a void but surely this is no different than going through a 12 inch wall I've had a look in tb17 but maybe I'm not looking hard enough?
That's what I thought but the fella was adamant it should have a hatch (no joint in the ceiling)
if no joins in the ceiling no hatch required the GSE that inspected has either misinterpreted the rules or does not understand the flues in voids requirements
Reactions: 2 people
I offered but silly fool pays management fees to the estate agents so says he wants to get his money's worth outta them
its TB008 ed 2 you want to be looking in, but i cant see a hatch being required
I'm doing a lot of these inspections just now and from my perspective I would say a hatch isn't required. Perhaps the Estate agents GSE is hoping to make money fitting hatches?
Yeah ces I think you're spot on! there's no loft space zee the bottom of the joist is the top of the plasterboard
I'm with SimonJohns on this - how can you be sure there isn't a dodgy bodged joint in the void? Common sense dictates that the vert flue terminal should have been dropped straight through the flat roof flashing and be long enough to clear the 6" void, but if it was a second hand flue component(I know it doesn't bear thinking about) or cut wrong, then you would have to be sure it was all correct. I think the estate managers 'belt and braces' approach makes sense and if unsure of history of install, fit an inspection hatch. Nightmare if its artex ceiling though - asbestos worries?
Yes That makes sense. all depends how the flue has been installed. someone probably covering their back.
I think i read somewhere that you should put some documentation with any grey area regarding flues in voids, so the next GSR engineer knows whats going on.
How would the next plumber be 100% sure there's no joints?
Because the length of the vertical flue terminal should go all the way through to well below ceiling. No need to joint in the void at all. Not saying I'm correct, but that's how id see it.
Getting interesting this 'flues in voids' issue IMO.
I am encountering more and more properties with double insulated roof spaces and a warning notice stating that safe access equipment and crawling boards should be used when accessing the loft.
Not easy or attractive when all your doing is a CP12 on a steamer with a vertical flue.
E
1K
E
