Feb 26, 2020
27
DIY or Homeowner
Howdy,
I am moving my cold water tank in my apartment bathroom and, as space is tight, I want to use a 90-degree elbow immediately after the water outlet at the bottom of the tank.
The tank was fitted when the place was built here in Dublin 27 years ago.
Here is the tank outlet:
This image shows the existing tank connector and the old fitting which was attached to it towards the top of the image, that had a slow bend on it which I want to replace with an elbow. I can't find a suitable elbow for this.
I found this on an American website, I need something like this, bot obviously one that will fit my tank outlet.
I bought some 22mm (1.5 inch) elbows but can't find one that fits. Here we see a comparison of the nut from the old attachment with a nut from a newly bought 22mm elbow, the old nut seems bigger.
Here is the tank connector diameter.
Any idea what connection I need and where I can get it in the UK or Ireland?
Tanks a lot! 🙂
Regards,
David
Can use this with a rubber washer and a brass 3/4” tap back nut.
It’s a 3/4” Male iron to 22mm compression elbow, in brass.
Can get a Male iron with longer thread if needed but they are expensive.
Thanks guys,
Ben, since I'm working with copper (so far anyway) I bought the two pieces you recommended at Screwfix.
Here they are with the old nut in the background
I assembled them as shown here:
I have to sayI am not entirely sure how to attach this to the tank, is the idea that both the tank outlet and the 3/4” Male iron to 22mm compression elbow both thread into the 3/4” tap back nut? One from each end? I am not sure about this.
In the first post I measured the diameter of the tank outlet, it was 27.55mm, here I measured the threaded part of the 3/4” Male iron to 22mm compression elbow, it is 26.19mm, almost 1.5mm off. It's not a big difference but still.....
... it does mean that the 3/4” tap back nut will not thread on to my old tank outlet:
So I am not sure what to do from here.
Maybe I should just disconnect my old tank outlets and get new ones? I don't really want to break every connection I've got but maybe its best?
I could try one of these two?
As always, gentlemen, your advice is greatly appreciated!
Dave
Thanks Shaun, thanks Ben. I see what you mean now.
Unfortunately, when I put a washer inside and outside the tank I can't get on to the thread with the nut. The thread is not long enough.
Ben, you mentioned it should be possible to get a male iron to 22mm compression elbow with a longer thread, do you have any idea where I could buy one?
I bought a pair of those Prestex Bent Male Iron Tank Connectors, Shaun, these look ideal for the job. Not cheap but it's the right fitting for what I need.
Thanks!
I am only now getting around to installing these. I've just noticed that the new Prestex Bent Male Iron Tank Connectors are smaller than the original ones that I am replacing. 18.8mm interior on the new versus 21mm in the old.
What do you think, is this a problem?
As a reminder on what I am doing here, this is to connect a standard cold water tank in an apartment hotpress to the hot tank just below it and the rest of the bathroom cold fittings.
As with everything in plumbing sometimes you have to be creative a rubber washer with a poly one on top fitted internally in the tank should do it , your other option is PTFE the 3/4 BSP thread 20 turns push through the tank add a fibre washer smeared with a pipe sealant suitable for potable water add a poly washer then the nut and tighten that should take up the gap for you . Regards kop
Hey folks.
Shaun asked for the OD which I believe means Outside Diameter. This is shown below, in mm and inches.
OLD FITTING:
NEW FITTING:
Is there any issue with the reduced flow of water through the new fitting given that it's 0.06 inches or 1.4mm narrower?
Or is it that the problem you guys see is that it will be more difficult to create a tight waterproof seal with the tank when installing the new fittings?
I paid about €80 euro (£70 GBP) for those two Prestex Bent Male Iron Tank Connectors so I do hope I don't have to dump them.
Thanks again guys!
Dave
I'd say they will be fine a rubber washer against the inside of the tank , with 2 poly washers one either side nut on and tighten 😉👍 kop
